[GeoNode-users] map latitude longitude from mouse position and xml
akaki ratiani ratiani at mia.gov.ge
Mon Feb 22 23:28:19 PST 2016
Hello, I cannot find  any convertors "xml to shapfile" .We do not use  Leaflet , we want convertor witch convert xml in shapfile or kml ! Can you give me any suggestions?
-----Original Message-----
From: Stefan Steiniger [mailto:sstein at geo.uzh.ch]
Sent: 10 ноября 2015 г. 23:23
To: akaki ratiani; geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] map latitude longitude from mouse position and xml
perhaps you should rather look at using Leaflet : http://leafletjs.com/ if you just want to publish this radar position info alone and not other data.
You have to convert the xml to a shapfile which can be load by GeoNode - except that your XML is a "kml", then you can use it straight. Perhaps you can do the conversion with GDAL? Or convert your xml to csv before?
best,
stefan
Am 10.11.15 um 05:11 schrieb akaki ratiani:
> 1)I am interesting, does Geonode support map latitude longitude when I
> moving cursor  position.
> If geonode does not have this function, we will be glad if the stuff
> can add this future. That would be great  update.
> 2) I have xml file which shows radars  position movements (in xml file
> is - latitude, longitude coordinates that are changing every 1 minute).
> I’d like to add this file like a layer on map ,which will display our
> radars. I do not know how to do this, Can you help me in this item?
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
