[GeoNode-users] Configure geonode behind a Proxy
Simone Dalmasso simone.dalmasso at gmail.com
Thu Feb 25 02:55:16 PST 2016
Annalisa, I think you are fine with that. You don't need to add it to
the PROXY_ALLOWED_HOSTS
as this parameters is used to tell the geonode internal proxy where it can
connect ( to do a getCapabilities to an external service).
The location should stay to localhost as long as geoserver and geonode are
on the same server.
2016-02-25 11:51 GMT+01:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
> Hi all,
> I have to configure geonode behind a proxy. The Proxy will map the request
> from "geomap.arpa.veneto.it" to my new server.
> I have fill in "Proxy Base Url" in geoserver's setting page with: "
> http://geomap.arpa.veneto.it/geoserver/"
> Then I have set SITEURL = 'http://geomap.arpa.veneto.it' and added that
> url in ALLOWED_HOSTS and PROXY_ALLOWED_HOSTS in local_settings.py file
> There are other things to do?
> I have to launch a geonode-updateip geomap.arpa.veneto.it ?
> LOCATION in OGC_SERVER, in local_settings.py, remains = ''
> http://localhost:8080/geoserver/'' ?
> I have to set, instead, the parameter  PROXY_URL ? To what?
> Thanks
> Annalisa
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160225/121123b2/attachment.html>
More information about the geonode-users mailing list
