[GeoNode-users] Permissions for layers and maps - LDAP
Christian Braun christian.braun at list.lu
Fri Feb 26 05:46:40 PST 2016
Dear all,
I would like to take this mail from last year.
I have the same problem over here. What is the solution? How can I solve this?
Many thanks in advance,
Christian
Christian Braun,
Luxembourg Institute of Science and Technology (LIST)
Environmental Research & Innovation (ERIN) Department
41, rue du Brill
L-4422 Belvaux
Tel: +352 42 59 91 - 6608
Fax : +352 275 885
E-mail : christian.braun at list.lu
Web:  www.list.lu
Hi, not sure how that works, but seems that since the user is external from
the geonode database it doesn't have the custom permissions like
"base.view_resourcebase" which is necessary to access the resources details
pages.
2015-09-08 17:58 GMT+02:00 Vincent Hussey <vincent.hussey at opw.ie>:
> Hi Group,
> I am having a problem viewing a layer and a map created by a user.
> I installed GeoNode on Ubuntu 14.04 using the Quick Start instructions.
> I have set up ldap authentication using django_auth_ldap, with the
> following settings in local_settings.py:
> AUTHENTICATION_BACKENDS = (
>     'django_auth_ldap.backend.LDAPBackend',
>     'django.contrib.auth.backends.ModelBackend',
> AUTH_LDAP_SERVER_URI = "ldap://ldap.example.com" # my ldap server url
> AUTH_LDAP_BIND_DN = ""
> AUTH_LDAP_BIND_PASSWORD = ""
> #AUTH_LDAP_USER_SEARCH = LDAPSearch("ou=,dc=ldap,dc=example,dc=com",
> AUTH_LDAP_USER_SEARCH = LDAPSearch("o=ORG",
> #,ou=,dc=ldap,dc=example,dc=com",
>     ldap.SCOPE_SUBTREE, "(uid=%(user)s)")
> #AUTH_LDAP_BIND_AS_AUTHENTICATING_USER = True
> #AUTH_LDAP_USER_DN_TEMPLATE = "cn=%(user)s"
> # Populate the Django user from the LDAP directory.
> AUTH_LDAP_USER_ATTR_MAP = {
>     "first_name": "givenName",
>     "last_name": "sn",
>     "email": "mail"
> #AUTH_LDAP_USER_FLAGS_BY_GROUP = {
> #    "is_active": "cn=active,ou=django,ou=groups,dc=example,dc=com",
> #    "is_staff": "cn=staff,ou=django,ou=groups,dc=example,dc=com",
> #    "is_superuser": "cn=superuser,ou=django,ou=groups,dc=example,dc=com"
> AUTH_LDAP_CONNECTION_OPTIONS = {
>     ldap.OPT_DEBUG_LEVEL: 1,
>     ldap.OPT_REFERRALS: 0,
> This allows a user to successfully authenticate.
> The user can upload a shapefile layer, but when he tries to access the
> layer at http://url/layers/layer_name , this error appears:
> Not Permitted
> You are not allowed to perform this operation.
> Please verify that you are logged in as the correct user.
> Similarly, the user can create a map and save it, but when he tries to
> access the map at http://url/maps/3/ the same error appears.
> Any help appreciated,
> Regards,
> Vincent
More information about the geonode-users mailing list
