[GeoNode-users] Basemaps not showing up if printed
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jan 7 06:36:05 PST 2016
Ok,
any chance that your server is under a proxy or something like this?
You should check if your server is able to get one of those images, maybe
logging in with ssh and do a wget on one of those addresses.
2016-01-07 15:31 GMT+01:00 Florian Hoedt <florian.hoedt at hs-owl.de>:
> Here is he log:
> http://pastebin.com/zTvT0cLS
> The errors are listed at line 2419
> 2016-01-07 15:23:48,993 ERROR [print.PDFUtils] - Server returned an error
> for http://otile1.mqcdn.com/tiles/1.0.0/map/09/268/169.png:
> Verbindungsaufbau abgelehnt
> for http://otile1.mqcdn.com/tiles/1.0.0/map/09/268/170.png:
> 2016-01-07 15:23:48,994 ERROR [print.PDFCustomBlocks] - Error while adding
> a PDF elementjava.io.IOException: Verbindungsaufbau abgelehnt
> Where “Verbindungsaufbau abgelehnt“ translates to „connection refused“.
> mit freundlichen Grüßen
> Florian Hoedt
> B.Sc. Florian Hoedt
> Hochschule Ostwestfalen-Lippe / Campus Höxter
> FB 9 Landschaftsarchitektur und Umweltplanung
> An der Wilhelmshöhe 44
> 37671 Höxter
> Tel.: 05271-687-7478
> E-Mail: florian.hoedt at hs-owl.de
> www.hs-owl.de/fb9
> *Von:* Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> *Gesendet:* Donnerstag, 7. Januar 2016 15:08
> *An:* Florian Hoedt
> *Cc:* geonode-users at lists.osgeo.org
> *Betreff:* Re: [GeoNode-users] Basemaps not showing up if printed
> Hi Florian,
> could you post the stacktrace on a pastebin site?
> 2016-01-07 12:09 GMT+01:00 Florian Hoedt <florian.hoedt at hs-owl.de>:
> Hello list,
> If I print a map the basemap will not get drawed – but will show up on the
> geoexplorer web view. It tells me there is a java.io error and connection
> issue on the pdf file.
> My settings are:
> Geoserver ProxyBase URL:
> http://geonode.aes.hs-owl.de/geoserver
> Any hints where to look?
> Florian Hoedt
> B.Sc. Florian Hoedt
> 37671 Höxter
> www.hs-owl.de/fb9
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160107/a974f027/attachment.html>
More information about the geonode-users mailing list
