[GeoNode-users] Geonode error "page not found" on production install
Ivo Santos ivojfs at gmail.com
Sat Jan 9 09:36:12 PST 2016
Simone,
Thank you for your help. I am testing on a lamp instalation on my laptop.
For now I will test other aspects and leave that part for the production
environment.
Best regards,
Ivo
2016-01-08 10:42 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Ivo, if your server doesn't have a name (just the ip address) then you
> cannot have multiple sites under the root. if you have a domain name then
>  you can take a look at the apache virtualhost configuration
> https://httpd.apache.org/docs/2.2/vhosts/examples.html.
> hope this helps
> 2016-01-08 11:39 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>> Hi Simone,
>> Thank you for showing me the correct way. I managed to use geonode on a
>> subdomain like you suggested. But now every other site on the server is
>> giving error "Bad Request (400)". Probably this is a common error due to my
>> inexperience with apache. If this questions are not for this list please
>> let me know.
>> Regards,
>> Ivo
>> 2016-01-08 7:36 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Hi Ivo,
>>> Geonode works at the root of the domain and you cannot serve it under
>>> /geonode unless you change the code or maybe do some tricks with Apache.
>>> Not sure if someone else has tried that. The suggestion is to keep at the
>>> root but serve it with an Apache virtualhost when you have a domain name.
>>> Like geonode.yourdomain.com.
>>> Regards
>>> Il giovedì 7 gennaio 2016, Ivo Santos <ivojfs at gmail.com> ha scritto:
>>>> Hi everyone,
>>>> I am new to geonode and testing the possibility of using it on my work.
>>>> For now, I am trying to install Geonode for production.
>>>> I instaled via apt-get with the snapshots repository on latest version
>>>> of ubuntu. After that I created the superuser, updated the ip and after
>>>> that changed the local_settings.py (SITEURL = '
>>>> http://10.0.2.15/geonode/') as on the docs
>>>> <http://docs.geonode.org/en/dev/deploy/production.html>. But when I
>>>> try to reach that page it appears "page not found". The homepage of geonode
>>>> remains http://10.0.2.15
>>>> Am I missing something here? Can you help me? If you need any kind of
>>>> information, please ask.
>>>> Best regards and thank you in advance,
>>>> Ivo
>>>> Ivo Santos
>>> Simone
>> Ivo Santos
> Simone
Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160109/38ed31c2/attachment.html>
More information about the geonode-users mailing list
