[GeoNode-users] Geonode error "page not found" on production install
Ivo Santos ivojfs at gmail.com
Thu Jan 14 04:17:01 PST 2016
Hello to everyone,
I already managed to solve the issue. I think that the problem I had on the
installation made me lose some geoserver configuration file. I can upload
layers and search them on the geoexplorer but they are no listed and the
layers do not appear on the map.
When I try to see a layer by itself the error is "Failed to load resource:
the server responded with a status of 401 (UNAUTHORIZED):
GET http://atlas.cidehusdigital.uevora.pt/security/permissions/1 401
(UNAUTHORIZED)" [http://atlas.example.com/static/lib/js/assets.min.js?v=2.4]
When I access geoserver the layer is there.
The log of apache:
Fatal Python error: PyEval_AcquireThread: NULL new thread state
[Thu Jan 14 12:14:12.309151 2016] [core:notice] [pid 10156] AH00051: child
pid 13857 exit signal Aborted (6), possible coredump in /etc/apache2
[Thu Jan 14 12:14:13.310554 2016] [core:notice] [pid 10156] AH00051: child
pid 2262 exit signal Aborted (6), possible coredump in /etc/apache2
[Thu Jan 14 12:14:14.311891 2016] [core:notice] [pid 10156] AH00051: child
pid 13860 exit signal Aborted (6), possible coredump in /etc/apache2
[Thu Jan 14 12:14:15.313226 2016] [core:notice] [pid 10156] AH00051: child
pid 13861 exit signal Aborted (6), possible coredump in /etc/apache2
[Thu Jan 14 12:14:16.314475 2016] [core:notice] [pid 10156] AH00051: child
pid 15953 exit signal Aborted (6), possible coredump in /etc/apache2
The error appears to be related. Do you have any idea of what can be
causing the problem?
Best regards,
Ivo
2016-01-13 9:52 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> I think it should but each configuration should live in it's own
> virtualhost, so one for suphp and one for geonode. with different
> subdomains.
> 2016-01-13 10:50 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>> Ok, can you tell me if geonode is compatible with suphp? I am trying to
>> explore if it is a compatibility issue.
>> 2016-01-13 9:48 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> that is definitely an apache misconfiguration, maybe of the php module.
>>> 2016-01-13 10:43 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>> Hi Simone,
>>>> Yes, tomcat was already instaled. I used the geoserver.war on that link
>>>> and now that part is working great.
>>>> For now the only problem it's just the link of the homepage. For
>>>> example, if I try to go to my homepage atlas.example.com I am being
>>>> redirected to atlas.example.com/init/index.php and not to the geonode
>>>> homepage.
>>>> I had a previous configuration with another webgis using that
>>>> subdomain. Do you think it could be a wrong configuration on apache or on
>>>> geonode?
>>>> Thank you for all the help and guidance,
>>>> Ivo
>>>> 2016-01-13 8:22 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>> Hi Ivo,
>>>>> one of the reasons why the apt-get installation can fail could be that
>>>>> on the machine there were already installed some of the components, in this
>>>>> case tomcat maybe.
>>>>> anyway if you install geoserver manually be sure to use the one
>>>>> provided by geonode
>>>>> http://build.geonode.org/geoserver/latest/geoserver.war.
>>>>> what link is broken, exactly?
>>>>> 2016-01-13 1:23 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>> Finnaly I got it almost working but for some reason it appears that
>>>>>> using the apt-get instalation, geoserver was not installed. Trying to
>>>>>> manual install it.
>>>>>> The homepage has also a problem. It's weird but it appears that
>>>>>> something redirects the link to some page that is not present on geonode.
>>>>>> All the other links are working correctly.
>>>>>> Thank you!
>>>>>> 2016-01-12 20:25 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>>> Hi everyone,
>>>>>>> So, after trying on localhost and themed my instalation to my needs,
>>>>>>> I am installing geonode on the production server. I am again with some
>>>>>>> doubts on the configuration. The automatic configuration file geonode.conf
>>>>>>> was changed by me on:
>>>>>>> <VirtualHost *:80>
>>>>>>>     Servername atlas.example.com
>>>>>>>     ServerAlias atlas.example.com
>>>>>>> When I try to reach geoserver I get a apache tomcat 404. should i
>>>>>>> change also on that file, the proxypass "localhost" to "
>>>>>>> atlas.example.com"? These are the lines:
>>>>>>>     ProxyPass /geoserver http://localhost:8080/geoserver
>>>>>>>     ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>>>>>> My 000-default.conf was working with the www.example.com on a CMS,
>>>>>>> now the configuration is redirecting to geoserver landing page. On other
>>>>>>> hand atlas.example.com shows geonode with "page not found error"
>>>>>>> On my local_settings.py I changed the SITEURL= '
>>>>>>> http://atlas.example.com' and ALLOWED_HOSTS=['atlas.example.com','
>>>>>>> www.example.com']
>>>>>>> Hoping that you can help me,
>>>>>>> Best regards,
>>>>>>> Ivo
>>>>>>> 2016-01-09 17:36 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>>>> Simone,
>>>>>>>> Thank you for your help. I am testing on a lamp instalation on my
>>>>>>>> laptop. For now I will test other aspects and leave that part for the
>>>>>>>> production environment.
>>>>>>>> Best regards,
>>>>>>>> Ivo
>>>>>>>> 2016-01-08 10:42 GMT+00:00 Simone Dalmasso <
>>>>>>>>> Ivo, if your server doesn't have a name (just the ip address) then
>>>>>>>>> you cannot have multiple sites under the root. if you have a domain name
>>>>>>>>> then  you can take a look at the apache virtualhost configuration
>>>>>>>>> https://httpd.apache.org/docs/2.2/vhosts/examples.html.
>>>>>>>>> hope this helps
>>>>>>>>> 2016-01-08 11:39 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>>>>>> Hi Simone,
>>>>>>>>>> Thank you for showing me the correct way. I managed to use
>>>>>>>>>> geonode on a subdomain like you suggested. But now every other site on the
>>>>>>>>>> server is giving error "Bad Request (400)". Probably this is a common error
>>>>>>>>>> due to my inexperience with apache. If this questions are not for this list
>>>>>>>>>> please let me know.
>>>>>>>>>> Regards,
>>>>>>>>>> Ivo
>>>>>>>>>> 2016-01-08 7:36 GMT+00:00 Simone Dalmasso <
>>>>>>>>>>> Hi Ivo,
>>>>>>>>>>> Geonode works at the root of the domain and you cannot serve it
>>>>>>>>>>> under /geonode unless you change the code or maybe do some tricks with
>>>>>>>>>>> Apache. Not sure if someone else has tried that. The suggestion is to keep
>>>>>>>>>>> at the root but serve it with an Apache virtualhost when you have a domain
>>>>>>>>>>> name. Like geonode.yourdomain.com.
>>>>>>>>>>> Regards
>>>>>>>>>>> Il giovedì 7 gennaio 2016, Ivo Santos <ivojfs at gmail.com> ha
>>>>>>>>>>> scritto:
>>>>>>>>>>>> Hi everyone,
>>>>>>>>>>>> I am new to geonode and testing the possibility of using it on
>>>>>>>>>>>> my work. For now, I am trying to install Geonode for production.
>>>>>>>>>>>> I instaled via apt-get with the snapshots repository on latest
>>>>>>>>>>>> version of ubuntu. After that I created the superuser, updated the ip and
>>>>>>>>>>>> after that changed the local_settings.py (SITEURL = '
>>>>>>>>>>>> http://10.0.2.15/geonode/') as on the docs
>>>>>>>>>>>> <http://docs.geonode.org/en/dev/deploy/production.html>. But
>>>>>>>>>>>> when I try to reach that page it appears "page not found". The homepage of
>>>>>>>>>>>> geonode remains http://10.0.2.15
>>>>>>>>>>>> Am I missing something here? Can you help me? If you need any
>>>>>>>>>>>> kind of information, please ask.
>>>>>>>>>>>> Best regards and thank you in advance,
>>>>>>>>>>>> Ivo
>>>>>>>>>>>> Ivo Santos
>>>>>>>>>>> Simone
>>>>>>>>>> Ivo Santos
>>>>>>>>> Simone
>>>>>>>> Ivo Santos
>>>>>>> Ivo Santos
>>>>>> Ivo Santos
>>>>> Simone
>>>> Ivo Santos
>>> Simone
>> Ivo Santos
> Simone
Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160114/ef95d4bf/attachment.html>
More information about the geonode-users mailing list
