[GeoNode-users] GeoNode Windows installer: looking for testers
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Jan 18 03:15:08 PST 2016
Thanks Daniel,
can you please check if Apache HTTPD service has started correctly? If so
can you try to see if in the $INSTALLDIR/Apache2/logs/error.log there is
something related to the issue?
Also, make a try by restarting the Apache HTTPD service.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Mon, Jan 18, 2016 at 12:12 PM, Daniel Victoria <daniel.victoria at gmail.com
> wrote:
> Dear Alessio,
> That's great news. I believe it will help spread the use of geonode to
> other niches...
> Anyway, I downloaded and installed the package in my machine. Installation
> went without a problem (no error screens). However, when I try to connect
> to http://localhost, it just keeps on waiting for the server response and
> nothing happens. I never see the GeoNode web page. I also tried 127.0.0.1.
> I'm not sure this is because I'm in a corporate domain and there might be
> some security blocks or if the installation did not work out. Later I'll
> try the installation on my personal computer. Meanwhile, if you'd like to
> figure out what happened, I can run the necessary tests, just give me the
> instructions as to what to do.
> Cheers
> Daniel
> On Mon, Jan 18, 2016 at 7:48 AM, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Dear all,
>> at this address
>> https://www.dropbox.com/s/ujclwt7mtu5zy87/GeoNode-2.4.exe?dl=0
>> you can find a first version of the GeoNode Windows installer.
>> The installer has been created using NSIS compiler and if it works fine
>> it will be part at the official GeoNode distribution and continuous build
>> as a result of the folowing GNIP:
>> https://github.com/GeoNode/geonode/issues/2375
>> The installer works by installing under a folder chosen by the user:
>> 1. A 32bit version of JRE 1.8
>> 2. A 32bit version of Python 2.7.10 with virtualenv and GDAL bindings
>> 3. A 32bit version of Apache Tomcat 7.0.35 with GeoServer
>> 4. A customized version of minimal WinLAMP with only the Apache HTTPD +
>> mod_wsgi
>> At the end of the installation you should be able to see:
>> 1. A running service of Apache Tomcat for GeoServer
>> 2. A running service of Apache HTTPD server for GeoNode
>> Your GeoNode installation will be available at:
>> http://localhost
>> Your GeoServer installation will be available at:
>> http://localhost/geoserver
>> No DB is installed on this version. The installation relies on the
>> default GeoNode settings.
>> It could be possible to optionally install also PostGIS in the future if
>> the community really needs it.
>> Also notice that the GeoNode will be configured to run in production mode
>> through the mod_wsgi and not in development mode through paver.
>> Please test it and report any feedbacks.
>> Very soon I will make available the NSIS source code too.
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts! Visit
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160118/4d2338f9/attachment.html>
More information about the geonode-users mailing list
