[GeoNode-users] Help with geonodeAuthProvider configuration
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Jan 20 07:19:23 PST 2016
The GeoNode/GeoServer security, right now, in order to work correctly needs
both GeoNode and GeoServer exposed under the same domain (and the same
port).
Therefore if you expose GeoNode as http://mysite/ you must also expose
GeoServer as http://mysite/geoserver
The GeoNode authentication provider can be configured with http://localhost,
I guess, but you must be sure that GeoServer is also exposed as
http://localhost/geoserver.
The rationale is that the GeoNodeSecurityClient looks for the AuthPrincipal
from the cookies.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Wed, Jan 20, 2016 at 3:58 PM, Ivo Santos <ivojfs at gmail.com> wrote:
> Hi everyone,
> After several limiting issues concerning the configuration of apache that
> I have to thank you especially to Simone for all the help and guidance, I
> am now with a problem with the connection between geonode and geoserver:
> If user as log in on geoserver but not on geonode, he can view the layers.
> If user is not loged on geoserver, he can not view the layers and the
> error is:
> 2016-01-20 14:39:59,947 WARN [geonode.security] - Error connecting to the
> GeoNode server for authentication purposes
> org.springframework.security.authentication.AuthenticationServiceException:
> Communication with GeoNode failed (UsernamePasswordAuthenticationToken)
> If user is logged on both geonode and geoserver it gives a internal error
> (500).
> Following this thread
> <https://groups.google.com/forum/m/#!topic/geonode-users/84HvjbarPE8>I
> tried to apply this doc
> <https://github.com/GeoNode/geonode/commit/cc732e0a73c6d04d8f57fdf376dfb9a9848abd86>to
> my installation but it didn't worked.
> Does it have to remain like "http://localhost/" on both files or should I
> substitute by "http://atlas.example.com" on both? If you need more info
> please let me know.
> Thank you for all the help and patience for this newcomer,
> regards,
> Ivo
> Ivo Santos
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160120/a0493a30/attachment.html>
More information about the geonode-users mailing list
