[GeoNode-users] Help with geonodeAuthProvider configuration
Ivo Santos ivojfs at gmail.com
Fri Jan 22 05:20:09 PST 2016
Alessio,
Thank you for the explanation about mod_wsgi. I think it wasn't the
situation. I tried the steps on that page who could be apllied and it's not
working. Inclusive, there was a step back. Now I am like before: the user
admin has to be logged to geoserver (and can't be logged on geonode) to be
able to see the layers on the geoexplorer.
I am trying now the geoexplorer debug as described on the documentation. It
has to be something wrong on the configuration. But what?
Thank you,
Ivo
2016-01-22 8:54 GMT+00:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> Well, specifically mod_wsgi is an Apache HTTPD module. It allows you to
> create a virtual folder/host in order to proxy the GeoNode DJango
> application.
> If you see mod_wsgi errors on the Apache error logs, most probably there
> is something wrong, which usually can be a configuration issue or a Python
> exception.
> In the GeoNode official documentation there are several pages showing the
> steps for the correct configuration of GeoNode with mod_wsgi.
> One page which may be helpful on your case maybe this one:
> http://docs.geonode.org/en/latest/tutorials/admin/customize_lookfeel/customize/setup_admin.html#setup-admin
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/NWWaa2 for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Thu, Jan 21, 2016 at 2:12 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>> It's not working on development mode.
>> Sorry the (probably) dumb question, but how can I use mod_wsgi to run
>> GeonNode?
>> Maybe this info could help. The error that appears on apache when the
>> user is logged on geonode and tries to see a layer is:
>>  mod_wsgi (pid=7536): Exception occurred processing WSGI script
>> '/var/www/geonode/wsgi/geonode.wsgi'.
>> And I realized that:
>> if the user is logged he can't see the layers (Example:
>> http://atlas.example.com/layers/geonode%3Acom26_wgs84 ) .
>> if the user tries to create a new map (
>> http://atlas.example.com/layers/maps/new) the layers appear as available
>> and could be shown on the map.
>> But if the user tries to save the map with the layers on screen, it gives
>> a 500 error.
>> Thank you in advance.
>> Best regards,
>> Ivo
>> 2016-01-21 13:01 GMT+00:00 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it>:
>>> One more thing, if you are running GeoNode in development mode (paver
>>> start_django) it may not work when running the embedded geoserver.
>>> If is not yet like this, try using mod_wsgi to run GeoNode
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Thu, Jan 21, 2016 at 1:30 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>>>> Alessio,
>>>> Thank you for your reply. I think that I did understand what you were
>>>> saying... After some improvements, geonode and geoserver are still unable
>>>> to communicate when a user is logged on geonode (this time, independently
>>>> of being logged on geoserver).
>>>> On local_settings.py:
>>>> # OGC (WMS/WFS/WCS) Server Settings
>>>> OGC_SERVER = {
>>>>     'default' : {
>>>>         'BACKEND' : 'geonode.geoserver',
>>>>         'LOCATION' : 'http://atlas.example.com:8080/geoserver/',
>>>>         'PUBLIC_LOCATION' : GEOSERVER_URL,
>>>>         'USER' : 'admin',
>>>>         'PASSWORD' : '*********************'
>>>> ALLOWED_HOSTS=['atlas.example.com']
>>>> On geonodeAuthProvider/config.xml:
>>>>   <baseUrl>http://atlas.example.com/</baseUrl>
>>>> Does anyone have a clue of what is the problem? It seems the same
>>>> problem Ariel had in November:
>>>> https://lists.osgeo.org/pipermail/geonode-users/2015-November/001150.html
>>>> Best regards,
>>>> Ivo
>>>> 2016-01-20 15:19 GMT+00:00 Alessio Fabiani <
>>>>> The GeoNode/GeoServer security, right now, in order to work correctly
>>>>> needs both GeoNode and GeoServer exposed under the same domain (and the
>>>>> same port).
>>>>> Therefore if you expose GeoNode as http://mysite/ you must also
>>>>> expose GeoServer as http://mysite/geoserver
>>>>> The GeoNode authentication provider can be configured with
>>>>> http://localhost, I guess, but you must be sure that GeoServer is
>>>>> also exposed as http://localhost/geoserver.
>>>>> The rationale is that the GeoNodeSecurityClient looks for the
>>>>> AuthPrincipal from the cookies.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Wed, Jan 20, 2016 at 3:58 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>>>>>> Hi everyone,
>>>>>> After several limiting issues concerning the configuration of apache
>>>>>> that I have to thank you especially to Simone for all the help and
>>>>>> guidance, I am now with a problem with the connection between geonode and
>>>>>> geoserver:
>>>>>> If user as log in on geoserver but not on geonode, he can view the
>>>>>> layers.
>>>>>> If user is not loged on geoserver, he can not view the layers and the
>>>>>> error is:
>>>>>> 2016-01-20 14:39:59,947 WARN [geonode.security] - Error connecting to
>>>>>> the GeoNode server for authentication purposes
>>>>>> org.springframework.security.authentication.AuthenticationServiceException:
>>>>>> Communication with GeoNode failed (UsernamePasswordAuthenticationToken)
>>>>>> If user is logged on both geonode and geoserver it gives a internal
>>>>>> error (500).
>>>>>> Following this thread
>>>>>> <https://groups.google.com/forum/m/#!topic/geonode-users/84HvjbarPE8>I
>>>>>> tried to apply this doc
>>>>>> <https://github.com/GeoNode/geonode/commit/cc732e0a73c6d04d8f57fdf376dfb9a9848abd86>to
>>>>>> my installation but it didn't worked.
>>>>>> Does it have to remain like "http://localhost/" on both files or
>>>>>> should I substitute by "http://atlas.example.com" on both? If you
>>>>>> need more info please let me know.
>>>>>> Thank you for all the help and patience for this newcomer,
>>>>>> regards,
>>>>>> Ivo
>>>>>> Ivo Santos
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Ivo Santos
>> Ivo Santos
Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160122/ff3fcded/attachment-0001.html>
More information about the geonode-users mailing list
