[GeoNode-users] Help with geonodeAuthProvider configuration
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Jan 26 07:45:10 PST 2016
I guess you have an old version of gsconfig installed on your system then.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Tue, Jan 26, 2016 at 4:43 PM, Ivo Santos <ivojfs at gmail.com> wrote:
> Ariel, thank you for sharing your experience. I am, of course, beginning
> to think seriously on the reinstall hypothesis.
> Alessio, the SLD URL on table "layers_style" was set to:
> "<bound method Style.body_href of <geoserver.style.Style object at
> 0x7f07a6038d10>>";
> 0x7efcb9dabed0>>";
> 0x7fb0e4a65f90>>"
> I tried to change it on every single layer to
> http://atlas.example.com:8080/geoserver/rest/styles/general.sld and it's
> working now.
> Tested to upload a new layer and to put the "Default Polygon" as defaut
> style and the same error occurs.
> The new layer on the SLD URL appear again the same type of
> 0x7fb0e4ec4690>>"
> After changing to the same url as above, every logged user can open the
> layers.
> But when I try to create a new map an internal 500 error occurs:
>    - On *apache *log:
> [Tue Jan 26 15:38:46.834380 2016] [authz_core:debug] [pid 8066]
> mod_authz_core.c(802): [client 193.136.219.68:63432] AH01626:
> authorization result of Require all granted: granted, referer:
> http://atlas.example.com/maps/new?layer=geonode:conc42_wgs84
> [Tue Jan 26 15:38:46.834414 2016] [authz_core:debug] [pid 8066]
> authorization result of <RequireAny>: granted, referer:
> [Tue Jan 26 15:38:46.834524 2016] [authz_core:debug] [pid 8066]
> [Tue Jan 26 15:38:46.834536 2016] [authz_core:debug] [pid 8066]
> [Tue Jan 26 15:38:47.299144 2016] [core:error] [pid 8066] [client
> 193.136.219.68:63432] End of script output before headers: geonode.wsgi,
> referer: http://atlas.example.com/maps/new?layer=geonode:conc42_wgs84
> [Tue Jan 26 15:38:47.972265 2016] [core:notice] [pid 1516] AH00051: child
> pid 10059 exit signal Segmentation fault (11), possible coredump in
> /etc/apache2
>    - on *geoserver *log:
> 2016-01-26 15:28:37,071 WARN [yaml.CustomBeanWrapper] - MetaData: unknown
> field 'footer' with value '{height=30,
> items=[org.mapfish.print.config.layout.ColumnsBlock at 141dedd2]}'
> 2016-01-26 15:28:37,085 WARN [yaml.CustomBeanWrapper] - MainPage: Error
> while writing '{height=30,
> items=[org.mapfish.print.config.layout.ColumnsBlock at 141dedd2]}' to
> footer: java.lang.IllegalArgumentException: argument type mismatch
> 2016-01-26 15:28:40,364 WARN [yaml.CustomBeanWrapper] - MetaData: unknown
> items=[org.mapfish.print.config.layout.ColumnsBlock at 35ef1451]}'
> Thank you,
> Regards,
> Ivo
> 2016-01-26 8:47 GMT+00:00 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>:
>> Mmm, thinking ... maybe the issue is just the SLD URL stored on the DB.
>> Try to change manually the geoserver URL on the table "layer_style" and
>> see if it works.
>> GeoServer Professional Services from the experts! Visit
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Tue, Jan 26, 2016 at 5:10 AM, Ariel Cabezas <gerardoarielc at gmail.com>
>> wrote:
>>> Ivo,
>>> I tell you my experience:
>>> *(Does anyone have a clue of what is the problem? It seems the same
>>> problem Ariel had in
>>> November: https://lists.osgeo.org/pipermail/geonode-users/2015-November/001150.html
>>> <https://lists.osgeo.org/pipermail/geonode-users/2015-November/001150.html>)*
>>> My problems started when:
>>> - Install GeoNode and default settings; upload some layers;
>>> later,
>>> - I did the steps to set GeoNode for Production
>>> - I change the key geoserver from the web platform Geoserver without
>>> changing the key in the file local_settings.py
>>> then I tried to upload new data layers; and of course they began error
>>> messages
>>> and I could not go back to the settings.  don't remember that changes
>>> made.
>>> mistakes were mine;
>>> I had to reinstall GeoNode and could change the key geoserver without
>>> any problem; and then load the data layers without problems too,
>>> now everything works correctly
>>> regards,
>>> Ariel Cabezas
>>> 2016-01-25 19:28 GMT-03:00 Ivo Santos <ivojfs at gmail.com>:
>>>> Alessio,
>>>> The same error occurs on both situations. It only depends of being
>>>> logged to geonode or not. Do you think I should reinstall geonode and
>>>> geoserver?
>>>> Regards,
>>>> Ivo
>>>> 2016-01-25 17:47 GMT+00:00 Alessio Fabiani <
>>>>> Is your layer a raster or vectorial one?
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Fri, Jan 22, 2016 at 4:06 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>>>>>> Nevermind the last email. In my tests to try to solve the issue, I
>>>>>> erased the trailing slash of the <baseUrl> on
>>>>>> geonodeAuthProvider/config.xml.
>>>>>> I am on the same point right now (I can't see the layers on
>>>>>> geoexplorer only if any geonode user is logged on). Possibily is something
>>>>>> like this error and I missed some slash or something like that.
>>>>>> I tryed "DEBUG = TEMPLATE_DEBUG = True" on local_settings.py
>>>>>> I am not sure if it helps, but the error that appears is:
>>>>>> IndexError at /layers/geonode:teste
>>>>>> list index out of range
>>>>>> Request Method:GET
>>>>>> Request URL:http://atlas.example.com/layers/geonode:teste
>>>>>> Django Version:1.6.1
>>>>>> Exception Type:IndexError
>>>>>> Exception Value:
>>>>>> Exception
>>>>>> Location:/usr/local/lib/python2.7/dist-packages/geonode/layers/models.py in
>>>>>> absolute_url, line 68
>>>>>> Python Executable:/usr/bin/python
>>>>>> Python Version:2.7.6
>>>>>> Python Path:
>>>>>> ['/usr/lib/python2.7',
>>>>>>  '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>>>>>>  '/usr/lib/python2.7/lib-tk',
>>>>>>  '/usr/lib/python2.7/lib-old',
>>>>>>  '/usr/lib/python2.7/lib-dynload',
>>>>>>  '/usr/local/lib/python2.7/dist-packages',
>>>>>>  '/usr/lib/python2.7/dist-packages',
>>>>>>  '/usr/lib/python2.7/dist-packages/PILcompat',
>>>>>>  '/usr/lib/pymodules/python2.7',
>>>>>>  '/var/www']
>>>>>> Server time:Sex, 22 Jan 2016 08:59:55 -0600
>>>>>> Error during template rendering
>>>>>> In template
>>>>>> /usr/local/lib/python2.7/dist-packages/geonode/layers/templates/layers/layer_detail.html,
>>>>>> error at line *322*
>>>>>> *<a href="{{ GEOSERVER_BASE_URL }}{{ style.absolute_url }}" >{{
>>>>>> style.sld_title }}</a>*
>>>>>> I can try to send the all file if some of you think it would be
>>>>>> better.
>>>>>> Thank you for your attention,
>>>>>> Ivo
>>>>>> 2016-01-22 13:20 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>>> Alessio,
>>>>>>> Thank you for the explanation about mod_wsgi. I think it wasn't the
>>>>>>> situation. I tried the steps on that page who could be apllied and it's not
>>>>>>> working. Inclusive, there was a step back. Now I am like before: the user
>>>>>>> admin has to be logged to geoserver (and can't be logged on geonode) to be
>>>>>>> able to see the layers on the geoexplorer.
>>>>>>> I am trying now the geoexplorer debug as described on the
>>>>>>> documentation. It has to be something wrong on the configuration. But what?
>>>>>>> Thank you,
>>>>>>> Ivo
>>>>>>> 2016-01-22 8:54 GMT+00:00 Alessio Fabiani <
>>>>>>>> Well, specifically mod_wsgi is an Apache HTTPD module. It allows
>>>>>>>> you to create a virtual folder/host in order to proxy the GeoNode DJango
>>>>>>>> application.
>>>>>>>> If you see mod_wsgi errors on the Apache error logs, most probably
>>>>>>>> there is something wrong, which usually can be a configuration issue or a
>>>>>>>> Python exception.
>>>>>>>> In the GeoNode official documentation there are several pages
>>>>>>>> showing the steps for the correct configuration of GeoNode with mod_wsgi.
>>>>>>>> One page which may be helpful on your case maybe this one:
>>>>>>>> http://docs.geonode.org/en/latest/tutorials/admin/customize_lookfeel/customize/setup_admin.html#setup-admin
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Italy
>>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>> On Thu, Jan 21, 2016 at 2:12 PM, Ivo Santos <ivojfs at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> It's not working on development mode.
>>>>>>>>> Sorry the (probably) dumb question, but how can I use mod_wsgi to
>>>>>>>>> run GeonNode?
>>>>>>>>> Maybe this info could help. The error that appears on apache when
>>>>>>>>> the user is logged on geonode and tries to see a layer is:
>>>>>>>>>  mod_wsgi (pid=7536): Exception occurred processing WSGI script
>>>>>>>>> '/var/www/geonode/wsgi/geonode.wsgi'.
>>>>>>>>> And I realized that:
>>>>>>>>> if the user is logged he can't see the layers (Example:
>>>>>>>>> http://atlas.example.com/layers/geonode%3Acom26_wgs84 ) .
>>>>>>>>> if the user tries to create a new map (
>>>>>>>>> http://atlas.example.com/layers/maps/new) the layers appear as
>>>>>>>>> available and could be shown on the map.
>>>>>>>>> But if the user tries to save the map with the layers on screen,
>>>>>>>>> it gives a 500 error.
>>>>>>>>> Thank you in advance.
>>>>>>>>> Best regards,
>>>>>>>>> Ivo
>>>>>>>>> 2016-01-21 13:01 GMT+00:00 Alessio Fabiani <
>>>>>>>>>> One more thing, if you are running GeoNode in development mode
>>>>>>>>>> (paver start_django) it may not work when running the embedded geoserver.
>>>>>>>>>> If is not yet like this, try using mod_wsgi to run GeoNode
>>>>>>>>>> @alfa7691
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Italy
>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>> On Thu, Jan 21, 2016 at 1:30 PM, Ivo Santos <ivojfs at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Alessio,
>>>>>>>>>>> Thank you for your reply. I think that I did understand what you
>>>>>>>>>>> were saying... After some improvements, geonode and geoserver are still
>>>>>>>>>>> unable to communicate when a user is logged on geonode (this time,
>>>>>>>>>>> independently of being logged on geoserver).
>>>>>>>>>>> On local_settings.py:
>>>>>>>>>>> # OGC (WMS/WFS/WCS) Server Settings
>>>>>>>>>>> OGC_SERVER = {
>>>>>>>>>>>     'default' : {
>>>>>>>>>>>         'BACKEND' : 'geonode.geoserver',
>>>>>>>>>>>         'LOCATION' : 'http://atlas.example.com:8080/geoserver/',
>>>>>>>>>>>         'PUBLIC_LOCATION' : GEOSERVER_URL,
>>>>>>>>>>>         'USER' : 'admin',
>>>>>>>>>>>         'PASSWORD' : '*********************'
>>>>>>>>>>> ALLOWED_HOSTS=['atlas.example.com']
>>>>>>>>>>> On geonodeAuthProvider/config.xml:
>>>>>>>>>>>   <baseUrl>http://atlas.example.com/</baseUrl>
>>>>>>>>>>> same problem Ariel had in November:
>>>>>>>>>>> Best regards,
>>>>>>>>>>> Ivo
>>>>>>>>>>> 2016-01-20 15:19 GMT+00:00 Alessio Fabiani <
>>>>>>>>>>>> The GeoNode/GeoServer security, right now, in order to work
>>>>>>>>>>>> correctly needs both GeoNode and GeoServer exposed under the same domain
>>>>>>>>>>>> (and the same port).
>>>>>>>>>>>> Therefore if you expose GeoNode as http://mysite/ you must
>>>>>>>>>>>> also expose GeoServer as http://mysite/geoserver
>>>>>>>>>>>> The GeoNode authentication provider can be configured with
>>>>>>>>>>>> http://localhost, I guess, but you must be sure that GeoServer
>>>>>>>>>>>> is also exposed as http://localhost/geoserver.
>>>>>>>>>>>> The rationale is that the GeoNodeSecurityClient looks for the
>>>>>>>>>>>> AuthPrincipal from the cookies.
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> Italy
>>>>>>>>>>>> On Wed, Jan 20, 2016 at 3:58 PM, Ivo Santos <ivojfs at gmail.com>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> Hi everyone,
>>>>>>>>>>>>> After several limiting issues concerning the configuration of
>>>>>>>>>>>>> apache that I have to thank you especially to Simone for all the help and
>>>>>>>>>>>>> guidance, I am now with a problem with the connection between geonode and
>>>>>>>>>>>>> geoserver:
>>>>>>>>>>>>> If user as log in on geoserver but not on geonode, he can view
>>>>>>>>>>>>> the layers.
>>>>>>>>>>>>> If user is not loged on geoserver, he can not view the layers
>>>>>>>>>>>>> and the error is:
>>>>>>>>>>>>> 2016-01-20 14:39:59,947 WARN [geonode.security] - Error
>>>>>>>>>>>>> connecting to the GeoNode server for authentication purposes
>>>>>>>>>>>>> org.springframework.security.authentication.AuthenticationServiceException:
>>>>>>>>>>>>> Communication with GeoNode failed (UsernamePasswordAuthenticationToken)
>>>>>>>>>>>>> If user is logged on both geonode and geoserver it gives a
>>>>>>>>>>>>> internal error (500).
>>>>>>>>>>>>> Following this thread
>>>>>>>>>>>>> <https://groups.google.com/forum/m/#!topic/geonode-users/84HvjbarPE8>I
>>>>>>>>>>>>> tried to apply this doc
>>>>>>>>>>>>> <https://github.com/GeoNode/geonode/commit/cc732e0a73c6d04d8f57fdf376dfb9a9848abd86>to
>>>>>>>>>>>>> my installation but it didn't worked.
>>>>>>>>>>>>> Does it have to remain like "http://localhost/" on both files
>>>>>>>>>>>>> or should I substitute by "http://atlas.example.com" on both?
>>>>>>>>>>>>> If you need more info please let me know.
>>>>>>>>>>>>> Thank you for all the help and patience for this newcomer,
>>>>>>>>>>>>> regards,
>>>>>>>>>>>>> Ivo
>>>>>>>>>>>>> Ivo Santos
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>> Ivo Santos
>>>>>>>>> Ivo Santos
>>>>>>> Ivo Santos
>>>>>> Ivo Santos
>>>> Ivo Santos
> Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160126/a77e6ef6/attachment-0001.html>
More information about the geonode-users mailing list
