[GeoNode-users] Geoserver can't see changes
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jan 28 05:05:35 PST 2016
I see,
we released the stable version last November, which is available on
ppa:geonode/stable.
Anyway, in order to understand your issue we need more information, what do
you mean by editing wms cascade?
Also in geoserver you can find the log page, it would be good if you could
check for errors there.
2016-01-28 13:59 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
> Hi
> Geonode I not installed, but with these steps was installed:
> *Install from PPA in Ubuntu 14.04*
> $ sudo add-apt-repository ppa:geonode/testing
> $ sudo apt-get update
> $ sudo apt-get install geonode
> Set the IP address and create a superuser
> $ sudo geonode-updateip 127.0.0.1
> $ geonode createsuperuser
> 2016-01-28 4:01 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi. How did you install geonode? Take look at the geoserver and Apache
>> logs they will give you more info.
>> Il mercoledì 27 gennaio 2016, Rosario Peña <roelpeag at gmail.com> ha
>> scritto:
>>> The geoserver can't see the changes did in the geonode, if I delete a
>>> layer, this layer remains in the geoserver and I can't  edit the layers WMS
>>> cascade because I get a Internal Server Error.
>> Simone
> Ing. Rosario Peña
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160128/d926eff9/attachment-0001.html>
More information about the geonode-users mailing list
