[GeoNode-users] Geoserver can't see changes
Rosario Peña roelpeag at gmail.com
Thu Jan 28 05:31:21 PST 2016
I mean editing metada of layers WMS. I started Django in debug mode and
verbose logging in Geoserver and I get a error: "Permission denied save
thumbnail"
2016-01-28 8:05 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> I see,
> we released the stable version last November, which is available on
> ppa:geonode/stable.
> Anyway, in order to understand your issue we need more information, what
> do you mean by editing wms cascade?
> Also in geoserver you can find the log page, it would be good if you could
> check for errors there.
> 2016-01-28 13:59 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>> Hi
>> Geonode I not installed, but with these steps was installed:
>> *Install from PPA in Ubuntu 14.04*
>> $ sudo add-apt-repository ppa:geonode/testing
>> $ sudo apt-get update
>> $ sudo apt-get install geonode
>> Set the IP address and create a superuser
>> $ sudo geonode-updateip 127.0.0.1
>> $ geonode createsuperuser
>> 2016-01-28 4:01 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Hi. How did you install geonode? Take look at the geoserver and Apache
>>> logs they will give you more info.
>>> Il mercoledì 27 gennaio 2016, Rosario Peña <roelpeag at gmail.com> ha
>>> scritto:
>>>> The geoserver can't see the changes did in the geonode, if I delete a
>>>> layer, this layer remains in the geoserver and I can't  edit the layers WMS
>>>> cascade because I get a Internal Server Error.
>>> Simone
>> Ing. Rosario Peña
> Simone
Ing. Rosario Peña
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160128/2e2ee8c2/attachment.html>
More information about the geonode-users mailing list
