[GeoNode-users] Geoserver can't see changes
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jan 28 12:49:02 PST 2016
This log is too big, maybe take a look at the apache log with
$ tail -f  /var/log/apache2/error.log
do a delete and see only the part that is generated with that operation.
2016-01-28 19:42 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
> This is the log that was generate in the moment of delete a layer, but
> that layer yet is in geoserver.
> 2016-01-28 12:00 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Sorry but 10 MB is too heavy for me and my connection is not very strong
>> where I am now. Try to catch only the relevant part. PS please keep posting
>> to the list.
>> 2016-01-28 16:23 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>>> I saw the log but isn't very clear for me. Anyway , I attached the log.
>>> 2016-01-28 9:19 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> If you delete in geonode, which has been uploaded via geonode, then it
>>>> should be removed from geoserver as well. I case check the geoserver logs
>>>> when this error occurs.
>>>> 2016-01-28 15:07 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>>>>> Great, it's work :D
>>>>> Another error is that Geoserver not take the changes made in the
>>>>> Geonode. Any idea why???
>>>>> 2016-01-28 8:36 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>>> Ok that is an issue of the old releases, but is not the issue we are
>>>>>> looking for.
>>>>>> You can solve this with:
>>>>>> $ sudo chown -R www-data /var/www/geonode/
>>>>>> 2016-01-28 14:31 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>>>>>>> I mean editing metada of layers WMS. I started Django in debug mode
>>>>>>> and verbose logging in Geoserver and I get a error: "Permission denied save
>>>>>>> thumbnail"
>>>>>>> 2016-01-28 8:05 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com
>>>>>>>> I see,
>>>>>>>> we released the stable version last November, which is available on
>>>>>>>> ppa:geonode/stable.
>>>>>>>> Anyway, in order to understand your issue we need more information,
>>>>>>>> what do you mean by editing wms cascade?
>>>>>>>> Also in geoserver you can find the log page, it would be good if
>>>>>>>> you could check for errors there.
>>>>>>>> 2016-01-28 13:59 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>>>>>>>>> Hi
>>>>>>>>> Geonode I not installed, but with these steps was installed:
>>>>>>>>> *Install from PPA in Ubuntu 14.04*
>>>>>>>>> $ sudo add-apt-repository ppa:geonode/testing
>>>>>>>>> $ sudo apt-get update
>>>>>>>>> $ sudo apt-get install geonode
>>>>>>>>> Set the IP address and create a superuser
>>>>>>>>> $ sudo geonode-updateip 127.0.0.1
>>>>>>>>> $ geonode createsuperuser
>>>>>>>>> 2016-01-28 4:01 GMT-05:00 Simone Dalmasso <
>>>>>>>>>> Hi. How did you install geonode? Take look at the geoserver and
>>>>>>>>>> Apache logs they will give you more info.
>>>>>>>>>> Il mercoledì 27 gennaio 2016, Rosario Peña <roelpeag at gmail.com>
>>>>>>>>>> ha scritto:
>>>>>>>>>>> The geoserver can't see the changes did in the geonode, if I
>>>>>>>>>>> delete a layer, this layer remains in the geoserver and I can't  edit the
>>>>>>>>>>> layers WMS cascade because I get a Internal Server Error.
>>>>>>>>>> Simone
>>>>>>>>> Ing. Rosario Peña
>>>>>>>> Simone
>>>>>>> Ing. Rosario Peña
>>>>>> Simone
>>>>> Ing. Rosario Peña
>>>> Simone
>>> Ing. Rosario Peña
>> Simone
> Ing. Rosario Peña
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160128/7b40a4f3/attachment.html>
More information about the geonode-users mailing list
