[GeoNode-users] Layers and Grants
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jan 29 02:25:32 PST 2016
yeah it should count it.
could you file a ticket for this?
2016-01-29 11:18 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi,
> You’re rigth. It’s stored as a “wmsStore”..
> Should it be stored as remoteStore as well? Or perhaps it should count
> also wmsStore?  Does it make sense?
> Regards,
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 – M 627 923 170 – F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
> *********************  LEGE OHARRA   *******************   AVISOLEGAL
> *******************   DISCLAIMER   *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> Enviado el: viernes, 29 de enero de 2016 10:57
> Para: David Alda Fernandez de Lezea
> CC: geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] Layers and Grants
> If you add layers to geoserver and then run updatelayers then the owner is
> admin, correctly.
> Go to the admin panel and pick one of the "cascaded" layers, down in the
> menu there is a field name "StoreType" check what is the content of that. I
> suspect that is not among the ones that get considered for counting,
> 2016-01-29 8:09 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi,
> the thing is that whenever I add a layer to GeoServer (it doesn't matter
> If the user is staff or super-user or both) the owner of the layer is the
> "admin" (the one that has both super-user and staff checks activated) I
> don't know if this has something to do with it.
> The layers are taken from a WMS cascaded service.
> I've just added a shape through the upload layers form and it appears as
> counted.
> Regards,
> Agur bero bat,
> Arloa.
> kontserbatu gabe.
> Enviado el: jueves, 28 de enero de 2016 13:37
> Hi, no the admin is not useful for this, if they show up in the layers
> list page then they should also be counted.
> Could you check which is the StoreType of those layers? The homepage
> counts consider 'coverageStore', 'dataStore', 'remoteStore'.
> For the difference between staff and superuser, staff is for allowing the
> access to admin page while the superuser also has all the permissions over
> the whole site.
> 2016-01-28 11:53 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Maybe changing some grants in the admin interface should solve the problem?
> I've noticed that all the layers' owner is the admin that created the
> layers..
> By the way which are the differences between being staff and superuser?
> Agur bero bat,
> Arloa.
> kontserbatu gabe.
> -----Mensaje original-----
> De: geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] En
> nombre de David Alda Fernandez de Lezea
> Enviado el: jueves, 28 de enero de 2016 10:19
> Para: Simone Dalmasso
> Hi,
> No matter with which user I'm logged in , it doesn't count any layer. Even
> if I'm unlogged.
> Only a user with admin grants can add data directly into GeoServer so I
> suppose the correct way is to use that user..
> Or perhaps it has to be a current user with admin grants??
> Regards,
> Agur bero bat,
> Arloa.
> T 945 003 240 – M 627 923 170 – F 945 003 290 Hazi | Granja Modelo de
> *******************   DISCLAIMER   ***************************** Mezu hau
> pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago
> legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
> Enviado el: jueves, 28 de enero de 2016 10:09
> Hi, strange behavior indeed.
> Are you always logged in when visiting the two pages?
> Il giovedì 28 gennaio 2016, David Alda Fernandez de Lezea <dalda at hazi.eus>
> ha scritto:
> Hi,
> I have question/doubt.. In my GeoNode installation I have several normal
> users and one Admin user. With the admin user I've loaded several cascaded
> WMS's into Geoserver and published several layers as well. I execute
> geonode update layers to synchronize and it goes OK. But when I visit
> geonode's main web page it appears (0 layers, 0 maps, 12 users). There're
> no maps, I know that because we're still at an initial phase, but 0 layers?
> The thing is that if I go into the layers page I can see the layer list
> that I already loaded. Is this something related to the user that used to
> load the layers? Maybe this is a normal behavior?
> Any ideas?
> Thanks in advance,
> Regards,
> Agur bero bat,
> Arloa.
> T 945 003 240 - M 627 923 170 - F 945 003 290 Hazi | Granja Modelo de
> Arkaute s/n | 01192 Arkaute - Araba
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160129/4073afff/attachment.html>
More information about the geonode-users mailing list
