[GeoNode-users] Region list problem
Jeffrey Johnson ortelius at gmail.com
Fri Jan 29 06:13:44 PST 2016
Im not sure that apt-get upgrade will actually upgrade you to 2.4
final since we changed the repository name to stable specifically so
users wouldnt encounter adverse side effects like this.
But yes, as I mention, delete the records out of the table using the
admin interface. Add them way you want them and then dump the fixtures
to a json file and keep it safe for the future. See here [1] and use
dumpdata / loaddata
[1] https://docs.djangoproject.com/en/1.9/howto/initial-data/
Jeff
On Fri, Jan 29, 2016 at 4:39 PM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> We installed and updated using apt-get. God ol "apt-get upgrade geonode"
> The apt-get runs the import process for the fixtures again? So, in the
> furure, every time I upgrade geonode, I'll have to import the region table
> again?
> Thanks
> Daniel
> On Fri, Jan 29, 2016 at 10:30 AM, Jeffrey Johnson <ortelius at gmail.com>
> wrote:
>> How do you have GeoNode installed and how did you upgrade? I suspect
>> the upgrade process re-ran the import of the default fixtures which
>> probably reused some of the IDs from your changed regions.
>> My recommendation is just to empty this table and reimport or readd
>> your data and then dump the fixtures to a json file for future use.
>> Let us know if that works.
>> Jeff
>> On Fri, Jan 29, 2016 at 2:24 PM, Daniel Victoria
>> > Hi list,
>> > A couple of months ago I changed the region list in our geonode,
>> > removing
>> > most of the countries in the world and adding the Brazilian states. This
>> > was
>> > done through the Geonode admin interface (Metadata region) and I put,
>> > for
>> > each Brazilian state, Brazil as the parent. Back then we were using
>> > GeoNode
>> > 2.4beta (can't recall the correct version).
>> > Recently I went to check on the region list and all the countries I
>> > removed
>> > came back. The Brazilian states are still there but they are all messed
>> > up
>> > in the region list, with some brazilian states being under Chile, for
>> > example. But in the admin interface, the parent is set correctly.
>> > The only change we did in Geonode was to update to the 2.4 final
>> > version.
>> > Does this update bring back the old countries, changing our base_region
>> > table?
>> > Or is there some type of block that will not let me remove some of the
>> > countries?
>> > Cheers
>> > Daniel
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
