[GeoNode-users] Using geonode-updateip when installing from source
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jul 5 00:40:22 PDT 2016
you can run manually the steps that geonode-updateip does.In particular
once you setup the new url in setting you can run these commands as pyhton
manage.py command
https://github.com/GeoNode/geonode/blob/master/package/support/geonode.updateip#L115.
hope this helps
2016-07-05 9:27 GMT+02:00 David Kennewell <david.kennewell at hydrata.com>:
> This follows on from the CMS email chain, but it's a different, quick
> question so a new email.
> I've installed geonode using
> git clone https://github.com/GeoNode/geonode.git
> cd geonode
> sudo pip install -e .
> Is there a way to get "geonode-updateip" working easily under these
> conditions? Or should I just keep updating things manually (which works but
> is prone to human error).
> thanks
> Dave
> David Kennewell
> Water Resources Engineer
> Hydrata.com
> +971 55 409 7378
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160705/cc76fe44/attachment.html>
More information about the geonode-users mailing list
