[GeoNode-users] Using geonode-updateip when installing from source
David Kennewell david.kennewell at hydrata.com
Tue Jul 5 01:09:40 PDT 2016
Yup, that works. Thanks Simone.
David Kennewell
Water Resources Engineer
Hydrata.com
+971 55 409 7378
On Tue, Jul 5, 2016 at 11:40 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi,
> you can run manually the steps that geonode-updateip does.In particular
> once you setup the new url in setting you can run these commands as pyhton
> manage.py command
> https://github.com/GeoNode/geonode/blob/master/package/support/geonode.updateip#L115.
> hope this helps
> 2016-07-05 9:27 GMT+02:00 David Kennewell <david.kennewell at hydrata.com>:
>> This follows on from the CMS email chain, but it's a different, quick
>> question so a new email.
>> I've installed geonode using
>> git clone https://github.com/GeoNode/geonode.git
>> cd geonode
>> sudo pip install -e .
>> Is there a way to get "geonode-updateip" working easily under these
>> conditions? Or should I just keep updating things manually (which works but
>> is prone to human error).
>> thanks
>> Dave
>> David Kennewell
>> Hydrata.com
>> +971 55 409 7378
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160705/4fdecbb3/attachment.html>
More information about the geonode-users mailing list
