[GeoNode-users] Settings for migration scripts
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jul 8 03:30:50 PDT 2016
I think that tuning the two params will make it work also for custom
installations.
2016-07-08 11:56 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm>:
> Hi Simone,
> My "settings.py" already has a defition
> of "ANONYMOUS_USER_ID". But your pointer
> provided me with the right idea.
> The script works if I use the following
> in "gn_migration.cfg":
>  [path]
>  geonode_path = /usr/local/lib/python2.7/dist-packages/geonode/
>  settings_path = geonode.settings
> This works for a plain 2.4 install from
> the official Ubuntu packages. Maybe adding
> to the migration docs?
> Cheers,
> Ben
> On 08/07/16 09:08, Simone Dalmasso wrote:
> > Hi, you can add this to your settings
> > https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L406
> >  2016-07-08 8:53 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm
> > <mailto:benducke at fastmail.fm>>:
> > Dear All --
> > I am in the process of migrating a GeoNode 2.0 instance to GeoNode
> > 2.4.
> > I am following the instructions here:
> https://github.com/capooti/geonode/blob/migration_from20_to_24/scripts/migrations/migrate20to24/index.rst
> >  ... and I have downloaded the migration scripts mentioned on the
> > page above.
> > At the last step, "create_auth_group_and_update_res.py" throws this
> > error message:
> > django.core.exceptions.ImproperlyConfigured: In order to use
> > django-guardian's ObjectPermissionBackend authorization backend you
> > have to configure ANONYMOUS_USER_ID at your settings module
> > I assume that the problem is a wrong setting in the "[path]" section
> > of "gn_migration.cfg"
> > My current settings are:
> > [path] geonode_path =
> > /usr/local/lib/python2.7/dist-packages/geonode/ settings_path =
> > geonode.local_settings
> > What would be the correct settings for a GeoNode installation on
> > Ubuntu 14.04 using the official packages?
> > Thanks and best,
> > Ben _______________________________________________ geonode-users
> > mailing list geonode-users at lists.osgeo.org
> > <mailto:geonode-users at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/geonode-users
> > -- Simone
> Dr. Benjamin Ducke
> {*} Geospatial Consultant
> {*} GIS Developer
> Spatial technology for the masses, not the classes:
> experience free and open source GIS at http://gvsigce.org
> geonode-users mailing list
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160708/81c62591/attachment-0001.html>
More information about the geonode-users mailing list
