[GeoNode-users] java heap size error uploading shapefile
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jul 12 23:07:59 PDT 2016
Hi, i see this in the logs "ERROR: relation "planpsvec_zones" does not
exist" it looks like there is a database configuration issue and geoserver
can't access it or is accessing another database different from the one you
imported the data.is that possible?
2016-07-13 8:02 GMT+02:00 Chris Jones <Chris.Jones at sunshinecoast.qld.gov.au>
> Hi Alessio/Dan
> I made the java changes as suggested and it appears to get a bit further.
> I now get this error:
> An exception occurred loading data to PostGIS- java.lang.RuntimeException:
> java.io.IOException: Error occured calculating bounds for planpsvec_zones
> Dan - To answer your questions in the previous email
> Geoserver is running on jetty
> Geonode is apache
> Both are Ubuntu EC2 instances sitting behind AWS load balancers.
> I have attached the geoserver log file, logging is currently to
> production_logging. I can amend this if it will provide you more
> information but it gets pretty large in size quickly.
> I have imported the data into postigs database with the import extension
> on the server fine, so the data appears to be ok.
> Thanks
> Chris
> *From:* alessio.fabiani at gmail.com [mailto:alessio.fabiani at gmail.com] *On
> Behalf Of *Alessio Fabiani
> *Sent:* Wednesday, 13 July 2016 3:30 AM
> *To:* Daniel Berry <dberry at boundlessgeo.com>
> *Cc:* Chris Jones <Chris.Jones at sunshinecoast.qld.gov.au>;
> geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] java heap size error uploading shapefile
> Hi Chris,
> it is a bit strange the fact that you are getting a heap OOM error, as
> Daniel already said, it would be very useful to take a look at some logs in
> order to get some more info on the issue.
> In any case, if you upgraded the available memory on your server you
> should also update the JVM Options.
> If I understood correctly you now have about 8Gb RAM available, so maybe
> could be helpful to set the options like follows:
> JAVA_OPTS="-Xms1024m -Xmx*4096*m -XX:MaxPermSize=*1024*m"
> NOTE: maybe 4Gb is too much for your needs, it depends on your specific
> use case. You can also try with 2048m.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, Jul 12, 2016 at 6:25 PM, Daniel Berry <dberry at boundlessgeo.com>
> wrote:
> Chris,
> Is it possible to send any logs? Also what is your configuration:
> Proxy Server - Apache/NGINX
> Application Server - Tomcat/Jetty/JBOSS
> Respectfully,
> Dan
> On Mon, Jul 11, 2016 at 7:27 PM, Chris Jones <
> Chris.Jones at sunshinecoast.qld.gov.au> wrote:
> Hi all
> I’m trying to upload a 200mb shapefile from Geonode into a RDS postgis
> database and keep getting a java heap size error. I have a separate EC2
> instance running geoserver and have increased the instance to
> T2 large so have 8gb RAM. Geoserver has no other layers and is not in
> production so it’s not being heavily used at all.
> I’ve also tested different settings for the java heap size (see below).
> This is what it’s currently set to. I have increased these settings but the
> error persists.
> JAVA_OPTS="-Xms1024m -Xmx1024m -XX:MaxPermSize=512m"
> Can anyone advise what to try next?? Is there a limitation on shapefile
> size??
> Any help would be greatly appreciated.
> Thanks
> Chris
> Chris Jones | Geospatial Analyst
> Geospatial & Asset Systems
> Information Communications Technology Services | Sunshine Coast Council
> *Phone:  07 5475 8717*
> *Email: * *Chris.Jones at Sunshinecoast.qld.gov.au
> <Chris.Jones at Sunshinecoast.qld.gov.au>*
> *Address: * Locked Bag 72 Sunshine Coast Mail Centre QLD 4560.
> *Website: * http://maps.sunshinecoast.qld.gov.au/MyMaps
> P Please consider the environment before printing this email
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> *Daniel Berry*
> Senior Software Engineer | Boundless
> 512-468-3946 (cell)
> @boundlessgeo
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160713/8001b19d/attachment-0001.html>
More information about the geonode-users mailing list
