[GeoNode-users] MapQuest changed direct tile access
Daniel Victoria daniel.victoria at gmail.com
Wed Jul 13 07:08:08 PDT 2016
This worked for my saved maps. Thanks.
But how about the layers page (e.g.: /layers/geonode%4A<some layer name>) ?
I'm still getting Mapquest as default background. Where do I change that?
cheers
Daniel
On Wed, Jul 13, 2016 at 10:09 AM, Simone Dalmasso <simone.dalmasso at gmail.com
> wrote:
> Hi, the following commands will use mapnik instead of mapquest background
> for all saved maps:
> $ geonode shell
> >>>from geonode.maps.models import MapLayer
> >>>MapLayer.objects.filter(name='osm').update(visibility=False)
> >>>MapLayer.objects.filter(name='mapnik').update(visibility=True)
> for new maps you can remove the mapquest entries in MAP_BASELAYERS.
> Hope this helps
> 2016-07-13 14:45 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>> Hi list,
>> This is probably affecting others. I just opened a layer in GeoNode and
>> saw that MapQuest changed their direct tile access policy [1]. Thus, the
>> background of all my layers are messed up.
>> How can I make geonode use some other basemap as default? Or fix my
>> basemap issue?
>> Thanks
>> Daniel
>> [1] -
>> http://devblog.mapquest.com/2016/06/15/modernization-of-mapquest-results-in-changes-to-open-tile-access/
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160713/e6517db7/attachment.html>
More information about the geonode-users mailing list
