[GeoNode-users] MapQuest changed direct tile access
Daniel Victoria daniel.victoria at gmail.com
Wed Jul 13 07:29:27 PDT 2016
Great, will try that. Thanks
On Wed, Jul 13, 2016 at 11:12 AM, Simone Dalmasso <simone.dalmasso at gmail.com
> wrote:
> Hi, you have to remove mapquest from your settings like here
> https://github.com/GeoNode/geonode/commit/42d589cd9d86fa76fc9a9afd2eeacdf64c939705
> and make mapnik the default one like here:
> https://github.com/GeoNode/geonode/commit/8cb080534e69c590c8864a2603b2ea1eca2e8a73
> 2016-07-13 16:08 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>> Hi,
>> This worked for my saved maps. Thanks.
>> But how about the layers page (e.g.: /layers/geonode%4A<some layer name>)
>> ? I'm still getting Mapquest as default background. Where do I change that?
>> cheers
>> Daniel
>> On Wed, Jul 13, 2016 at 10:09 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi, the following commands will use mapnik instead of mapquest
>>> background for all saved maps:
>>> $ geonode shell
>>> >>>from geonode.maps.models import MapLayer
>>> >>>MapLayer.objects.filter(name='osm').update(visibility=False)
>>> >>>MapLayer.objects.filter(name='mapnik').update(visibility=True)
>>> for new maps you can remove the mapquest entries in MAP_BASELAYERS.
>>> Hope this helps
>>> 2016-07-13 14:45 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>>> Hi list,
>>>> This is probably affecting others. I just opened a layer in GeoNode and
>>>> saw that MapQuest changed their direct tile access policy [1]. Thus, the
>>>> background of all my layers are messed up.
>>>> How can I make geonode use some other basemap as default? Or fix my
>>>> basemap issue?
>>>> Thanks
>>>> Daniel
>>>> [1] -
>>>> http://devblog.mapquest.com/2016/06/15/modernization-of-mapquest-results-in-changes-to-open-tile-access/
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160713/1278095f/attachment-0001.html>
More information about the geonode-users mailing list
