[GeoNode-users] custom geoserver data directory in geonode docker container
admire addloe at gmail.com
Fri Jul 15 03:30:54 PDT 2016
Hi
I am using the geonode in docker container and would like to set the
geoserver data directory not to be persistent with the container because
I would like to build and destroy the container without losing any data.
I know in geoserver if you need to have a different data directory you
have to change web.xml.
I can change that but how do I get to restart geoserver inside the
container so that the changes take effect.
Regards
More information about the geonode-users mailing list
