[GeoNode-users] Error creating superuser (gn2.4 on Debian)
Simone Dalmasso simone.dalmasso at gmail.com
Sun Jul 17 00:04:45 PDT 2016
Thanks. Actually the docs follow the stable release, so please do the Pr
and we will merge it when the 2.6 will be out.  Ciao.
Il domenica 17 luglio 2016, Cristian Zamar <cristian_zamar at hotmail.com> ha
scritto:
> Thank you Simone!! you were right about my wrong branch and now it works
> on Debian 8.5 :D
> I will PR some changes on the docs soon.
> Regards
> *Lic. CRISTIAN R. ZAMAR*
> Developer - GIS Specialist
> +54 370 4271736
> linkedin <http://ar.linkedin.com/in/cristianzamar>
> Hi, if you pulled from the master branch then is a Dev version with some
> changes. To create the db you have to use Python manage.py migrate.
> If you want to stay with 2.4 then checkout the branch 2.4.x.
> Hope this helps
> Il venerdì 15 luglio 2016, Cristian Zamar <cristian_zamar at hotmail.com
> <javascript:_e(%7B%7D,'cvml','cristian_zamar at hotmail.com');>> ha scritto:
> Hi all,
> I'm trying to install GeoNode 2.4 on Debian 8.5 following the manual
> installation from the docs:
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
> Everything was going right until this step:
> *python manage.py createsuperuser*
> the error log is:
> Traceback (most recent call last):
>   File "manage.py", line 29, in <module>
>     execute_from_command_line(sys.argv)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
>     utility.execute()
>   File
> line 346, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
> line 394, in run_from_argv
>     self.execute(*args, **cmd_options)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/management/commands/createsuperuser.py",
> line 50, in execute
>     return super(Command, self).execute(*args, **options)
>   File
> line 445, in execute
>     output = self.handle(*args, **options)
>   File
> line 105, in handle
> self.UserModel._default_manager.db_manager(database).get_by_natural_key(username)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/models.py",
> line 162, in get_by_natural_key
>     return self.get(**{self.model.USERNAME_FIELD: username})
>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line
> 127, in manager_method
>     return getattr(self.get_queryset(), name)(*args, **kwargs)
>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py",
> line 328, in get
>     num = len(clone)
> line 144, in __len__
>     self._fetch_all()
> line 965, in _fetch_all
>     self._result_cache = list(self.iterator())
> line 238, in iterator
>     results = compiler.execute_sql()
>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py",
> line 840, in execute_sql
>     cursor.execute(sql, params)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line
> 79, in execute
>     return super(CursorDebugWrapper, self).execute(sql, params)
>   File
> 64, in execute
>     return self.cursor.execute(sql, params)
>   File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line
> 98, in __exit__
>     six.reraise(dj_exc_type, dj_exc_value, traceback)
>   File
> 64, in execute
> django.db.utils.ProgrammingError: no existe la relación «people_profile»
> LINE 1: ...ofile"."zipcode", "people_profile"."country" FROM "people_pr...
> I see the geonode database is empty (no tables). Am I missing any step?
> I've tried with *syncdb* but I got a similar error.
> Hope you can help me.
> Thanks in advance.
> +54 370 4271736
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160717/6ac96b0d/attachment-0001.html>
More information about the geonode-users mailing list
