[GeoNode-users] Advanced Styling
Daniel Victoria daniel.victoria at gmail.com
Tue Jul 19 04:05:53 PDT 2016
This sounds really interesting. But maybe an easier path would be for
GeoNode to work nicely with SLD styles generated by QGis. What I've found
is that if I make a SLD style in QGis, it comes out as version 1.1.0. I
then copy the style directly to GeoServer and it works OK. But, if I try to
edit the style using the GeoNode style editor, if fails and the layer stops
working. I than have to remove the layer and add it again.
Cheers
Daniel
On Tue, Jul 19, 2016 at 6:23 AM, David Alda Fernandez de Lezea <
dalda at hazi.eus> wrote:
> Hi Paolo,
> Thanks for your response. Yes it's something that could be really
> interesting. From my point of view, unless I'm wrong, this functionality
> could be available/usable for all the layers stored in the "geonode"
> database, as they are the only layers that can be styled (WMS cascaded
> layers, which are foreign, layers can't), it would be possible to make
> query to the DB via python function, for example?
> Thanks.
> Regards.
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 – M 627 923 170 – F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
> *********************  LEGE OHARRA   *******************   AVISOLEGAL
> *******************   DISCLAIMER   *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> -----Mensaje original-----
> De: Paolo Corti [mailto:pcorti at gmail.com]
> Enviado el: lunes, 18 de julio de 2016 16:20
> Para: David Alda Fernandez de Lezea
> CC: geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] Advanced Styling
> It would be an interesting feature but I don't think there is any other
> way than reading all the field values with a WFS request and then compose
> the distinct values list on the client. Therefore it can be overwhelming
> for large datasets p
> On Mon, Jul 18, 2016 at 7:55 AM, David Alda Fernandez de Lezea
> <dalda at hazi.eus> wrote:
> > Hi list,
> > I'm looking for some custom functionalities on GeoNode and I'm thinking
> of allowing the "gxp_styler" to read the distinct values that has the
> selected attribute field that the user specifies to classify. I don't know
> if anyone else has tried or even completed this task.
> > In case not, I think it would be a good idea to include this in
> following versions of GeoNode.
> > Thanks in advance.
> > Regards,
> > Agur bero bat,
> Arloa.
> > T 945 003 240 - M 627 923 170 - F 945 003 290 Hazi | Granja Modelo de
> > Arkaute s/n | 01192 Arkaute - Araba
> kontserbatu gabe.
> > geonode-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160719/77663a9b/attachment.html>
More information about the geonode-users mailing list
