[GeoNode-users] Getting internal server error when trying to access layer page
Daniel Victoria daniel.victoria at gmail.com
Wed Jul 20 04:40:25 PDT 2016
Perfect Simone,
I removed the duplicate links and it all works now.
What I think might have happened for me to get duplicate links is that my
Geonode server has two addresses. An internal (intranet) and an external
(public). I first loaded all layers using the GeoNode shell, and the
local_settings was pointing to the internal address. I later changed
local_settings to point to the public address and uploaded this shapefile.
This might have given me the error. I also had to manually set the
thumbnail for all layers. So basicaly, I believe was a server URL settings
problem.
Once again, thanks
Daniel
On Wed, Jul 20, 2016 at 4:28 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, it's strange but looks like you have more than one "Legend Link" set
> per layer. I have no idea how this can happen but go to the "Link" section
> in the admin and make sure there's only one Legend link per layer. This
> should help.
> 2016-07-19 20:04 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>> Hi list,
>> I just noticed that 2 layers in my GeoNode server gives my an internal
>> server error (status 500) when I try to see the layer page
>> (layers/geonode%3Alayer_name_here).
>> The layers were uploaded using geonode shell and I can see it fine in
>> GeoServer layer preview. I can also create a new map and add the faulty
>> layer to it.
>> I can see the layer information in the GeoNode Admin panel and when I try
>> to delete it, I get the status 500 error again.
>> I tried looking at the apache error log but I could not figure out what
>> was wrong. So I attached the part of the error that happened the minute I
>> tryed to load the layer. Any idea what's wrong?
>> I'm running GeoNode 2.4 on Ubuntu, installed via apt-get
>> Thanks
>> Daniel
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160720/83e24d6e/attachment.html>
More information about the geonode-users mailing list
