[GeoNode-users] Layers Pink Tiles
Julierme Gonçalves Pinheiro juliermecoppe at hotmail.com
Mon Jun 6 09:55:38 PDT 2016
Dear all
I have been hitting a wall trying to understand the cause of some pink tiles.
Geonode was working fine, but I realized that it would properly work only under IP 192.168.0.X.
The IP was dynamic and I changed it to static 192.168.0.X (ethernet connection). Since then, I have created some SHP layers in geonode and when I click over the layer to see on the map, the response is pink tiles. When I add the layers, I see that they are created in geoserver (geonode workspace) as well and I have configured local_settings.py to ALLOWED_HOSTS=['localhost','192.168.0.X',].
Also, If I try to create a map for the layer, I get the following error:
Internal Server Error
The server encountered an internal error or
misconfiguration and was unable to complete
your request.
Please contact the server administrator at
 webmaster at localhost to inform them of the time this error occurred,
 and the actions you performed just before this error.
More information about this error may be available
in the server error log.
Apache/2.4.7 (Ubuntu) Server at 192.168.0.X Port 80
Checking Apache2 log files, I found something weird:
Not enabling BingMaps base layer as a BING_API_KEY is not defined in local_settings.py file.
[Mon Jun 06 11:44:59.441336 2016] [proxy_ajp:error] [pid 1577:tid 140692256978688] (120006)APR does not understand this error code: [client 127.0.0.1:36230] AH00878: read response failed from 127.0.0.1:8080 (localhost), referer: http://192.168.0.X/layers/geonode%3Aaerovias
[Mon Jun 06 11:44:59.448615 2016] [proxy_ajp:error] [pid 1578:tid 140692147873536] (70014)End of file found: AH01030: ajp_ilink_receive() can't receive header
Could someone help me on that please?
Thank you in advance for your time
JULIERME GONÇALVES PINHEIRO
_____________________________________________________________________________________________________________ " O AMOR É PACIENTE, É BENIGNO; O AMOR NÃO ARDE EM CIÚMES, NÃO SE UFANA, NÃO SE ENSOBERBECE, NÃO SE CONDUZ INCONVENIENTEMENTE, NÃO PROCURA OS SEUS INTERESSES, NÃO SE EXASPERA, NÃO SE RESSENTE DO MAL; NÃO SE ALEGRA COM A INJUSTIÇA, MAS REGOZIJA-SE COM A VERDADE; TUDO SOFRE, TUDO CRÊ, TUDO ESPERA, TUDO SUPORTA. O AMOR JAMAIS ACABA " I CORÍNTIOS 13: 4-8 _____________________________________________________________________________________________________________
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160606/10e11262/attachment.html>
More information about the geonode-users mailing list
