[GeoNode-users] FW: Running GeoNode 2.4 on Ubuntu
Jeffrey Johnson ortelius at gmail.com
Mon Jun 6 17:06:49 PDT 2016
Is http://localhost:8080/geoserver itself answering?
On Mon, Jun 6, 2016 at 5:04 PM, Franklin, Chris <
CFranklin at anglogoldashanti.com> wrote:
> Hi,
> The base url is:
> *1.  **Request URL:*
> http://localhost:8080/geoserver/wms?LAYERS=geonode%3Ageoheritage&FORMAT=image%2Fjpeg&TRANSPARENT=FALSE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=12523442.7125,-3757032.81375,13775786.98375,-2504688.5425&WIDTH=256&HEIGHT=256
> Thanks
> *Chris Franklin*
> GIS and Database Co-ordinator
> Exploration Australia
> Tel:         +61 08 9425 4719
> Fax:        +61 08 9425 4650
> Email:      cfranklin at anglogoldashanti.com
> Consider the environment. Think before you print.
> *From:* Jeffrey Johnson [mailto:ortelius at gmail.com]
> *Sent:* Tuesday, 7 June 2016 8:01 AM
> *To:* Franklin, Chris <CFranklin at AngloGoldAshanti.com>
> *Cc:* Simone Dalmasso <simone.dalmasso at gmail.com>;
> geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] FW: Running GeoNode 2.4 on Ubuntu
> Can you let us know what URL is being requested. We only see the wms part
> not the root URL
> On Mon, Jun 6, 2016 at 4:53 PM, Franklin, Chris <
> Hi,
> Sorry for the delay in replying, I have checked the errors in the F12 dev
> tools and found the connection was refused: (failed)
> net::ERR_CONNECTION_REFUSED – what do I need to do here?
> Thanks
> *Chris Franklin*
> *From:* Simone Dalmasso [mailto:simone.dalmasso at gmail.com
> <simone.dalmasso at gmail.com>]
> *Sent:* Saturday, 4 June 2016 6:22 PM
> *Cc:* Stefan Steiniger <sstein at geo.uzh.ch>; geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] Running GeoNode 2.4 on Ubuntu
> Hi, you can use the browser developer toolbar to track what happens when
> the client is requesting one of the urls that return a pink tile. In the
> network panel right click on one of the failing requests and open in a new
> tab. It should download a file containing some clues on the error.
> 2016-06-03 23:00 GMT+02:00 Franklin, Chris <CFranklin at anglogoldashanti.com
> Hi Stefan,
> Yes I do, with the style applied in geonode.
> Chris Franklin
> On 4 Jun 2016, at 02:33, Stefan Steiniger <sstein at geo.uzh.ch> wrote:
> Hi,
> could be an access problem. If you go as Admin to the Geoserver UI and
> check in the Layer-Preview using OpenLayers button, do you see your map
> data there?
> stefan
> ------ Originalnachricht ------
> *Von: *Franklin, Chris
> *Datum: *03.06.2016 11:40
> *An: *geonode-users at lists.osgeo.org;
> *Betreff:*[GeoNode-users] Running GeoNode 2.4 on Ubuntu
> I have the interface working no problem, can upload shp files but when
> trying to view in either the layer view of map view I get Geoservers pink
> squares of death?
> Can see the data in the openlayers view from GS itself sop I know the data
> is good.
> Can anyone help me out?
> *Chris *
> This email, and its attachments, is subject to important warnings and
> disclaimers which are legally incorporated into this email in terms of
> Section 11(3) of the South African Electronic Communications and
> Transactions Act, 25 of 2002. The full text of the warnings and
> disclaimers, together with the company details and directors is available
> by clicking on http://www.anglogoldashanti.com/en/Pages/legal.aspx
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160606/574226d1/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160606/574226d1/attachment-0002.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160606/574226d1/attachment-0002.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160606/574226d1/attachment-0003.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160606/574226d1/attachment-0003.jpg>
More information about the geonode-users mailing list
