[GeoNode-users] Deleted layers persist in Geonode
Simone Dalmasso simone.dalmasso at gmail.com
Mon Jun 6 22:53:16 PDT 2016
ok we will search for the error, in the meantime you can delete the layers
directly from the db maybe using pgadmin.
Hope this helps
2016-06-06 18:39 GMT+02:00 Nic Tait <ngtait at gmail.com>:
> Thanks Simone
> I believe the layers were added through Geoserver by cascading a remote
> WMS service as a new store, subsequently layers and store were deleted in
> Geoserver.The main Geonode screen reports the correct number of layers but
> the deleted layers are still visible in 'Explore Layers'. Geonode appears
> to function as normal apart from these 'ghost' layers that cannot be
> deleted.
> Regards
> Nick
> On Mon, Jun 6, 2016 at 8:02 AM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> Could you tell us more on how you loaded the layers?
>> Usually the best workflow is to manage them from within geonode and not
>> directly on geoserver.
>> PS, please always include the mailing list as others may benefit.
>> 2016-06-03 13:11 GMT+02:00 <ngtait at gmail.com>:
>>> Thanks Simo
>>> some of the error log below when I try to delete one layer
>>> [Fri Jun 03 03:47:17.378725 2016] [:error] [pid 26607:tid
>>> 140391119156992] Internal Server Error: /admin/layers/layer/
>>> [Fri Jun 03 03:47:17.378755 2016] [:error] [pid 26607:tid
>>> 140391119156992] Traceback (most recent call last):
>>> lines of django errrors
>>> [Fri Jun 03 03:47:17.378816 2016] [:error] [pid 26607:tid
>>> 140391119156992]     response = receiver(signal=self, sender=sender,
>>> **named)
>>> [Fri Jun 03 03:47:17.378818 2016] [:error] [pid 26607:tid
>>> 140391119156992]   File "/opt/geonode/geonode/geoserver/signals.py", line
>>> 36, in geoserver_pre_delete
>>> [Fri Jun 03 03:47:17.378820 2016] [:error] [pid 26607:tid
>>> 140391119156992]     cascading_delete(gs_catalog, instance.typename)
>>> [Fri Jun 03 03:47:17.378821 2016] [:error] [pid 26607:tid
>>> 140391119156992]   File "/opt/geonode/geonode/geoserver/helpers.py", line
>>> 230, in cascading_delete
>>> [Fri Jun 03 03:47:17.378823 2016] [:error] [pid 26607:tid
>>> 140391119156992]     workspace, name = layer_name.split(':')
>>> [Fri Jun 03 03:47:17.378825 2016] [:error] [pid 26607:tid
>>> 140391119156992] ValueError: too many values to unpack
>>> [Fri Jun 03 03:47:17.387151 2016] [:error] [pid 26607:tid
>>> 140391119156992] [remote 5.133.21.84:40545] mod_wsgi (pid=26607):
>>> Exception occurred processing WSGI script
>>> '/var/www/geonode/wsgi/geonode.wsgi'.
>>> more lines of django errors
>>> Nick
>>> <quote author='Simo D'>
>>> Hi, do you have any stacktrace from /var/logs/apache2/error.log of when
>>> you
>>> try to delete one layer from the admin console?
>>> 2016-06-02 22:18 GMT+02:00 Stefan Steiniger <sstein at geo.uzh.ch>:
>>> > Perhaps the last option may be to check the Database(s) directly, e.g.
>>> > connecting with PgAdmin.
>>> > stefan
>>> > On 02-06-2016 11:58, Nic Tait wrote:
>>> > Hello Geonode users,
>>> > I added layers to Geonode from an external service and then deleted
>>> them
>>> > in Geoserver but they are still visible as empty layers in 'Explore
>>> > Layers'
>>> > and the 'Admin console' within Geonode
>>> > I deleted the relevant layers , stores and workspace in Geoserver and
>>> > cannot find any other reference in Geoserver and then ran the
>>> management
>>> > command:
>>> > 'python manage.py updatelayers --remove-deleted'
>>> > which returned  '[delete_failed]' for all the layers
>>> > Layers are still visible in the admin console but get 'Internal Server
>>> > Error' when trying to delete them this way.
>>> > Have restarted Geonode with  'sudo service apache2 restart' as well to
>>> see
>>> > if that might fix but no luck
>>> > Any ideas on how to proceed ?
>>> > Regards,
>>> > Nic
>>> > _______________________________________________
>>> > geonode-users mailing
>>> > listgeonode-users at lists.osgeo.orghttp://
>>> lists.osgeo.org/mailman/listinfo/geonode-users
>>> > geonode-users mailing list
>>> > http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
>>> </quote>
>>> Quoted from:
>>> http://osgeo-org.1560.x6.nabble.com/Deleted-layers-persist-in-Geonode-tp5269594p5269682.html
>>> Sent from http://osgeo-org.1560.x6.nabble.com
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160607/5866f44c/attachment.html>
More information about the geonode-users mailing list
