[GeoNode-users] Error Updating Ip
Finnegan Pope-Carter f.pope-carter at magnitudesurveys.co.uk
Thu Jun 16 07:28:22 PDT 2016
Hi Paolo
Yes updatelayers has also completed successfully.
Finn
Sent: 16 June 2016 15:23
To: Finnegan Pope-Carter <f.pope-carter at magnitudesurveys.co.uk>
Cc: geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] Error Updating Ip
Oh I was not aware that updateip is also changing SITEURL in settings, good to know.
Did the updatelayers command within geonode.updateip also completed successfully?
p
On Thu, Jun 16, 2016 at 10:08 AM, Finnegan Pope-Carter <f.pope-carter at magnitudesurveys.co.uk<mailto:f.pope-carter at magnitudesurveys.co.uk>> wrote:
SITEURL was updated automatically by updateip and I’ve manually checked local_settings and printed the settings out of the Django shell. SITEURL is definitely gis.magnitudesurveys.com<http://gis.magnitudesurveys.com>
From: Paolo Corti [mailto:pcorti at gmail.com<mailto:pcorti at gmail.com>]
Sent: 16 June 2016 14:44
To: Finnegan Pope-Carter <f.pope-carter at magnitudesurveys.co.uk<mailto:f.pope-carter at magnitudesurveys.co.uk>>
Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Did you change SITEURL in your settings file?
p
On Thu, Jun 16, 2016 at 5:05 AM, Finnegan Pope-Carter <f.pope-carter at magnitudesurveys.co.uk<mailto:f.pope-carter at magnitudesurveys.co.uk>> wrote:
I originally had geonode running on the domain geonode.magnitudesurveys.com<http://geonode.magnitudesurveys.com>, I wanted to update the domain name to gis.magnitudesurveys.com<http://gis.magnitudesurveys.com>.
I’ve run sudo geonode-updateip gis.magnitudesurveys.com<http://gis.magnitudesurveys.com> which completes successfully.
When I navigate to a map view and inspect sources the majority of layers are still loading from geonode.magnitudesurveys.com<http://geonode.magnitudesurveys.com>. Am I missing a setting anywhere that needs updating as well as running updateip?
[cid:image001.png at 01D1C7E3.B7164A50]
Thanks in advance for your assistance
Finn
Finnegan Pope-Carter BSc (Hons) MSc FGS
Director of Research & Development
[horizontal-alpha_300px]<http://www.magnitudesurveys.co.uk/>
www.magnitudesurveys.co.uk<http://www.magnitudesurveys.co.uk>
Office: +44(0)1274 926020<tel:%2B44%280%291274%20926020>
Mobile: +44(0)1274 926022<tel:%2B44%280%291274%20926022>
The information in this email is confidential and solely for the use of the intended recipient(s). If you receive this email in error, please notify the sender and delete the email from your system immediately. In such circumstances, you must not make any use of the email or its contents.
Magnitude Surveys Ltd. Registered office: 50 Kirkgate, Shipley, West Yorkshire, BD18 3EL. Registered in England. Registered number: 09605400.
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160616/d8863610/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160616/d8863610/attachment-0002.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160616/d8863610/attachment-0003.png>
More information about the geonode-users mailing list
