[GeoNode-users] Error saving style back to server
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jun 22 02:41:14 PDT 2016
Hi, take a look at the apache logs when the 500 error code appears, they
should tell you more.
2016-06-21 20:12 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
> Hi list,
> I have a GeoNode instance running on Ubuntu, installed via
> apt-get.Everything appears to be working fine however, when I try to change
> a layer style, I get the error: "There was an error saving the style back
> to the server."
> Looking at the development console, I see that when I try to alter the
> layer style there are 2 PUT calls to the server. The first one fails with
> error 500 Internal server error. This is the call that's sending the SLD to
> the server. The second one returns 200 OK and it's sending the a JSON
> {"layer":{"defaultStyle":{"name":"estados"},"styles":{},"enabled":true}}
> I'm trying to debug this error but can't find what is going on. I'm
> running behind a proxy server. Could this be a security setting? Is it
> normal that one PUT call fails and the other works?
> Thanks
> Daniel
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160622/791f8949/attachment.html>
More information about the geonode-users mailing list
