[GeoNode-users] Error saving style back to server
Daniel Victoria daniel.victoria at gmail.com
Wed Jun 22 04:34:26 PDT 2016
Hi Simone,
Thanks for the tip. Looking at the apache2.log it appears that it's some
problem with a cerificateHostnameMismatch. Am I reading the log correct?
I'll talk to the people that maintains out network and see about this
certificate.
On the same topic, in local_setting.py what should I put in SITEURL. The
actual name of my virtual machine (some funny thing like dmzv014)? Or the
name it's known in the internet (https://www.some.pretty.name.here)
Thanks
Daniel
On Wed, Jun 22, 2016 at 6:41 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, take a look at the apache logs when the 500 error code appears, they
> should tell you more.
> 2016-06-21 20:12 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>> Hi list,
>> I have a GeoNode instance running on Ubuntu, installed via
>> apt-get.Everything appears to be working fine however, when I try to change
>> a layer style, I get the error: "There was an error saving the style
>> back to the server."
>> Looking at the development console, I see that when I try to alter the
>> layer style there are 2 PUT calls to the server. The first one fails with
>> error 500 Internal server error. This is the call that's sending the SLD to
>> the server. The second one returns 200 OK and it's sending the a JSON
>> {"layer":{"defaultStyle":{"name":"estados"},"styles":{},"enabled":true}}
>> I'm trying to debug this error but can't find what is going on. I'm
>> running behind a proxy server. Could this be a security setting? Is it
>> normal that one PUT call fails and the other works?
>> Thanks
>> Daniel
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160622/c99aa564/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160622/c99aa564/attachment-0001.obj>
More information about the geonode-users mailing list
