[GeoNode-users] database update error
Eugenio Trumpy frippe12573 at hotmail.com
Thu Jun 23 01:27:40 PDT 2016
Hi all,
today I was trying to update geonode from git (custom installation on ubuntu 14.04).
I made a backup of the data from geonode and geonode_data db, then I created new DBs,
and I run syncdb --noinput, but something seems not working:
System check identified some issues:
WARNINGS:
account.EmailConfirmation.created: (fields.W161) Fixed default value provided.
    HINT: It seems you set a fixed date / time / datetime value as default for this field. This may not be what you want. If you want to have the current date as default, use `django.utils.timezone.now`
dialogos.Comment.ip_address: (fields.W900) IPAddressField has been deprecated. Support for it (except in historical migrations) will be removed in Django 1.9.
    HINT: Use GenericIPAddressField instead.
Operations to perform:
  Synchronize unmigrated apps: tasks, dialogos, modeltranslation, django_extensions, polymorphic, agon_ratings, gis, pinax_theme_bootstrap_account, django_forms_bootstrap, catalogue, humanize, geoserver, announcements, storages, user_messages, mptt, friendlytagloader, staticfiles, geoexplorer, sitemaps, proxy, account, pinax_theme_bootstrap, pagination, autocomplete_light, messages, leaflet, api, avatar, social, security
  Apply all migrations: layers, documents, actstream, people, admin, guardian, sessions, djcelery, sites, auth, tastypie, maps, contenttypes, base, upload, groups, services, taggit
Synchronizing apps without migrations:
  Creating tables...
    Creating table account_account
    Creating table account_signupcode
    Creating table account_signupcodeextended
    Creating table account_signupcoderesult
    Creating table account_emailaddress
    Creating table account_emailconfirmation
    Creating table account_accountdeletion
    Creating table avatar_avatar
    Creating table dialogos_comment
    Creating table agon_ratings_overallrating
    Creating table agon_ratings_rating
    Creating table announcements_announcement
    Creating table announcements_dismissal
    Creating table user_messages_thread
    Creating table user_messages_userthread
    Creating table user_messages_message
    Running deferred SQL...
  File "manage.py", line 29, in <module>
    execute_from_command_line(sys.argv)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 354, in execute_from_command_line
    utility.execute()
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 346, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py", line 394, in run_from_argv
    self.execute(*args, **cmd_options)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py", line 445, in execute
    output = self.handle(*args, **options)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/syncdb.py", line 25, in handle
    call_command("migrate", **options)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 120, in call_command
    return command.execute(*args, **defaults)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/migrate.py", line 179, in handle
    created_models = self.sync_apps(connection, executor.loader.unmigrated_apps)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/migrate.py", line 318, in sync_apps
    cursor.execute(statement)
  File "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line 79, in execute
    return super(CursorDebugWrapper, self).execute(sql, params)
  File "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line 64, in execute
    return self.cursor.execute(sql, params)
  File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line 98, in __exit__
    six.reraise(dj_exc_type, dj_exc_value, traceback)
  File "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line 62, in execute
    return self.cursor.execute(sql)
django.db.utils.ProgrammingError: relation "people_profile" does not exist
Of course I performed the update of the dbs after run git pull on geonode dir.
Can you help me?
Eugenio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160623/ea830f3f/attachment.html>
More information about the geonode-users mailing list
