[GeoNode-users] osgeo module install problem
Francesco Bartoli xbartolone at gmail.com
Mon Jun 27 10:03:12 PDT 2016
Hi devs,
this issue still occurred with the current master branch and I have managed that in a virtualenv only by applying the workaround suggested by Paolo. For this reason I’ve created a small PR [1] in the documentation to avoiding that.
If you agreed then someone can merge.
Thx
Francesco
[1] #2527
Il giorno 09/lug/2015, alle ore 15:16, Vicente <deluca.vicente at gmail.com> ha scritto:
> You are right Paolo Corti, in my case I have gdal 1.11.2 installed by QGIS.
> The following documentation is mostly right: http://geonode.readthedocs.org/en/latest/tutorials/devel/install_devmode/gdal_install.html
> Pay attention to point 3:
> $ pip install --no-install GDAL==1.10.0
> $ nano build/GDAL/setup.cfg
> First download, not install, then edit setup.cfg to get the gdal file configuration from the system, gdal 1.11.2 in my case.
> The error in the above documentation is on how to download and install the library, $pip install --no-download GDAL==1.10.0 just not work because I never could locate the package downloaded by $ pip install --no-install GDAL==1.10.0.
> These were my steps to move forward:
> 1) In my (venv) download with wget the right gdal library
> 2) Edit setup.cfg like doc
> 3) Compile with $python setup.py build_ext --include-dirs=/usr/include/gdal
> 4) Move to gdal dir and run $pip install .
> 5) Get a fresh coffee
> Saludos!
> On Thu, Jul 9, 2015 at 5:29 AM, Simone Dalmasso <simone.dalmasso at gmail.com> wrote:
> For me the steps in the Jeff's script work well. although pygdal seems good.
> 2015-07-09 9:57 GMT+02:00 Paolo Pasquali <paolo.pasquali at ithaca.polito.it>:
> Sorry Paolo,
> I've just seen your reply after sending my email.
> The pip install pygdal==1.10.1 works for me so I was able to run paver sync.
> Thank you!
> Ciao
> P.
> On Thu, Jul 9, 2015 at 9:43 AM, Paolo Corti <pcorti at gmail.com> wrote:
> On Thu, Jul 9, 2015 at 9:34 AM, Paolo Pasquali <paolo.pasquali at ithaca.polito.it> wrote:
> Hey all,
> I think I am facing the same issue.
> I am trying to install GeoNode on a fresh Ubuntu 14 in virtualenv but I get the ImportError: No module named osgeo
> So I've tried to pip install GDAL==1.10.0
> but I get UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position 42: ordinal not in range(128)
> and I am stuck here.
> Thanks for your help!
> ciao Paolo
> if you did not customize things, Ubuntu 14 LTS comes with GDAL 1.10.1, therefore try to install pygdal 1.10.1 (there is not the corresponding package for gdal)
> $ yolk -V gdal
> GDAL 2.0.0
> (env)capooti at ubuntu:~/git/github$ yolk -V pygdal
> pygdal 1.11.2.1
> pygdal 1.11.1.1
> pygdal 1.11.0.1
> pygdal 1.10.1.1
> pygdal 1.10.0.1
> pygdal 1.9.2.1
> pygdal 1.8.1.1
> not sure why previous gdal versions where removed for the gdal package.
> cheers
> p
> [1]
> [2]
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
> Vicente Deluca
> +54 11 6091 4579
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160627/f99bd53b/attachment.html>
More information about the geonode-users mailing list
