[GeoNode-users] Geonode and ArcGIS Server
Jeffrey Johnson ortelius at gmail.com
Mon Jun 27 12:01:39 PDT 2016
Hi Xenia,
This should be possible if you have the required permissions on the
ArcGIS server to enable WMS and WFS (vs the default Image and Map
Services).
Its not quite ready yet, but you should be able to use django-mapproxy
in front of the Esri Server
https://github.com/terranodo/django-mapproxy
This will certainly require some development work and wont simply work
out of the box, but if you are prepared to put in some dev effort it
could be made to work.
Jeff
On Mon, Jun 27, 2016 at 6:01 AM, Xenia Specka <specka at zalf.de> wrote:
> Hi everyone,
> Has anyone ever tried to user ArcGIS Server as a map server in Geonode
> instead of Geoserver?
> I am a developer in a german research project and we want to implement a
> dataportal, with focus on geospatial data. I really would like to use
> Geonode, but I am forced to use ArcGIS Server as a map server. Is there
> hope, that we can develop an  interface to use ArcGIS server instead of
> Geoserver?
> Has anyone done this already?
> Kind regards
> Xenia Specka
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
