[GeoNode-users] Geonode and ArcGIS Server
Xenia Specka specka at zalf.de
Tue Jun 28 00:04:15 PDT 2016
Thanks for your advice. I will have a look at the Django-mapproxy. And I am aware, that we have to manually develop something, to connect Geonode and ArcGIS Server. Hopefully, we will be successful. Otherwise we have to use our fallback solution, which is ESRI Geoportal for Server.
Thanks again,
Xenia.
-----Ursprüngliche Nachricht-----
Von: Jeffrey Johnson [mailto:ortelius at gmail.com]
Gesendet: Montag, 27. Juni 2016 21:02
An: Xenia Specka
Cc: geonode-users
Betreff: Re: [GeoNode-users] Geonode and ArcGIS Server
Hi Xenia,
This should be possible if you have the required permissions on the ArcGIS server to enable WMS and WFS (vs the default Image and Map Services).
Its not quite ready yet, but you should be able to use django-mapproxy in front of the Esri Server https://github.com/terranodo/django-mapproxy
This will certainly require some development work and wont simply work out of the box, but if you are prepared to put in some dev effort it could be made to work.
Jeff
On Mon, Jun 27, 2016 at 6:01 AM, Xenia Specka <specka at zalf.de> wrote:
> Hi everyone,
> Has anyone ever tried to user ArcGIS Server as a map server in Geonode
> instead of Geoserver?
> I am a developer in a german research project and we want to implement
> a dataportal, with focus on geospatial data. I really would like to
> use Geonode, but I am forced to use ArcGIS Server as a map server. Is
> there hope, that we can develop an  interface to use ArcGIS server
> Has anyone done this already?
> Kind regards
> Xenia Specka
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
