[GeoNode-users] database update error
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jun 28 01:26:31 PDT 2016
Here
http://lists.osgeo.org/mailman/listinfo/geonode-users you can manage your
subscription
Regards.
Il martedì 28 giugno 2016, Farhan <farhanmoazzam at gmail.com> ha scritto:
> Anyone tell me that how to unsubscribe this email from geonode. As it's
> now irritating me.
> On Tue, Jun 28, 2016 at 12:52 PM, Simone Dalmasso <
> <javascript:_e(%7B%7D,'cvml','simone.dalmasso at gmail.com');>> wrote:
>> hm, nope.
>> try a pip install -e geonode maybe you miss something
>> 2016-06-28 9:42 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com
>> <javascript:_e(%7B%7D,'cvml','frippe12573 at hotmail.com');>>:
>>> Hi Simone,
>>> Django seems to be already at 1.6.11 version
>>> Any other hints?
>>> E.
>>> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com
>>> *Inviato:* lunedì 27 giugno 2016 17.56
>>> *A:* Eugenio Trumpy
>>> *Cc:* geonode-users at lists.osgeo.org
>>> <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
>>> *Oggetto:* Re: [GeoNode-users] database update error
>>> It's likely to be the django version. Django on 2.4 has to be 1.6.11
>>> 2016-06-27 16:40 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com
>>>> Hi Simone,
>>>> I forgot I had both the dbs backups and /geonode (the once I had before
>>>> the git pull) saved.
>>>> So I restore the old /geonode (I removed all the new geonode dir
>>>> obtained with the git pull) and restored the DBs dumps.
>>>> Everything seems to be working, I see the right number of the layers
>>>> and maps, groups, people...
>>>> However, clicking on layer I have an empty page (no layers available).
>>>> So I run python manage.py updatelayers, but I get:
>>>> Traceback (most recent call last):
>>>>   File "manage.py", line 29, in <module>
>>>>     execute_from_command_line(sys.argv)
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
>>>> line 399, in execute_from_command_line
>>>>     utility.execute()
>>>>   File
>>>> line 392, in execute
>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>   File
>>>> line 272, in fetch_command
>>>>     klass = load_command_class(app_name, subcommand)
>>>>   File
>>>> line 75, in load_command_class
>>>>     module = import_module('%s.management.commands.%s' % (app_name,
>>>> name))
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/utils/importlib.py", line
>>>> 40, in import_module
>>>>     __import__(name)
>>>>   File
>>>> "/dati/geonode/geonode/geoserver/management/commands/updatelayers.py", line
>>>> 24, in <module>
>>>>     from geonode.geoserver.helpers import gs_slurp
>>>>   File "/dati/geonode/geonode/geoserver/helpers.py", line 70, in
>>>> <module>
>>>>     from geonode.layers.utils import layer_type, get_files
>>>>   File "/dati/geonode/geonode/layers/utils.py", line 46, in <module>
>>>>     from geonode.layers.models import Layer, UploadSession
>>>>   File "/dati/geonode/geonode/layers/models.py", line 35, in <module>
>>>>     from geonode.base.models import ResourceBase, ResourceBaseManager,
>>>> resourcebase_post_save
>>>>   File "/dati/geonode/geonode/base/models.py", line 41, in <module>
>>>>     from mptt.models import MPTTModel, TreeForeignKey
>>>>   File "/usr/local/lib/python2.7/dist-packages/mptt/models.py", line
>>>> 15, in <module>
>>>>     from mptt.managers import TreeManager
>>>>   File "/usr/local/lib/python2.7/dist-packages/mptt/managers.py", line
>>>> 63, in <module>
>>>>     class TreeManager(models.Manager.from_queryset(TreeQuerySet)):
>>>> AttributeError: type object 'Manager' has no attribute 'from_queryset'
>>>> Any ideas?
>>>> E.
>>>> *Inviato:* lunedì 27 giugno 2016 14.39
>>>> *A:* Eugenio Trumpy
>>>> you can use the git branch 2.4.x. git checkout is the command.
>>>> 2016-06-27 14:25 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com
>>>>> Hi Simone,
>>>>> thank you for your answer so far.
>>>>> So my solution is to put the head of my git repo to the once that was
>>>>> working up to the last week, isn't it?
>>>>> How can I re-set the git head to such version? I don't remember the
>>>>> code version.
>>>>> Thanks
>>>>> E.
>>>>> *Inviato:* lunedì 27 giugno 2016 13.16
>>>>> *A:* Eugenio Trumpy
>>>>> Eugenio, sorry for the delay.
>>>>> I did not have time to test it on postgres so my suggestion at the
>>>>> moment is to stick with the 2.4 stable release.
>>>>> 2016-06-23 11:22 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com
>>>>>> Hi Simone,
>>>>>> django is at 1.8.7 version, is that correct for the master? how can I
>>>>>> check the version of the data model?
>>>>>> However, from empty geonode db I run manage.py migrate auth:
>>>>>>  System check identified some issues:
>>>>>> WARNINGS:
>>>>>> account.EmailConfirmation.created: (fields.W161) Fixed default value
>>>>>> provided.
>>>>>>     HINT: It seems you set a fixed date / time / datetime value as
>>>>>> default for this field. This may not be what you want. If you want to have
>>>>>> the current date as default, use `django.utils.timezone.now`
>>>>>> dialogos.Comment.ip_address: (fields.W900) IPAddressField has been
>>>>>> deprecated. Support for it (except in historical migrations) will be
>>>>>> removed in Django 1.9.
>>>>>>     HINT: Use GenericIPAddressField instead.
>>>>>> Operations to perform:
>>>>>>   Apply all migrations: auth
>>>>>> Running migrations:
>>>>>>   Rendering model states... DONE
>>>>>>   Applying contenttypes.0001_initial... OK
>>>>>>   Applying contenttypes.0002_remove_content_type_name... OK
>>>>>>   Applying auth.0001_initial... OK
>>>>>>   Applying auth.0002_alter_permission_name_max_length... OK
>>>>>>   Applying auth.0003_alter_user_email_max_length... OK
>>>>>>   Applying auth.0004_alter_user_username_opts... OK
>>>>>>   Applying auth.0005_alter_user_last_login_null... OK
>>>>>>   Applying auth.0006_require_contenttypes_0002... OK
>>>>>>   File
>>>>>> line 354, in execute_from_command_line
>>>>>>     utility.execute()
>>>>>>   File
>>>>>> line 346, in execute
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
>>>>>> line 394, in run_from_argv
>>>>>>     self.execute(*args, **cmd_options)
>>>>>>   File
>>>>>> line 445, in execute
>>>>>>     output = self.handle(*args, **options)
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/migrate.py",
>>>>>> line 226, in handle
>>>>>>     emit_post_migrate_signal(created_models, self.verbosity,
>>>>>> self.interactive, connection.alias)
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/sql.py",
>>>>>> line 280, in emit_post_migrate_signal
>>>>>>     using=db)
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py",
>>>>>> line 189, in send
>>>>>>     response = receiver(signal=self, sender=sender, **named)
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/django/contrib/sites/management.py",
>>>>>> line 20, in create_default_site
>>>>>>     if not Site.objects.using(using).exists():
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line
>>>>>> 586, in exists
>>>>>>     return self.query.has_results(using=self.db)
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/query.py",
>>>>>> line 484, in has_results
>>>>>>     return compiler.has_results()
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py",
>>>>>> line 811, in has_results
>>>>>>     return bool(self.execute_sql(SINGLE))
>>>>>>   File
>>>>>> line 840, in execute_sql
>>>>>>     cursor.execute(sql, params)
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line
>>>>>> 79, in execute
>>>>>>     return super(CursorDebugWrapper, self).execute(sql, params)
>>>>>>   File
>>>>>> 64, in execute
>>>>>>     return self.cursor.execute(sql, params)
>>>>>>   File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py",
>>>>>> line 98, in __exit__
>>>>>>     six.reraise(dj_exc_type, dj_exc_value, traceback)
>>>>>>   File
>>>>>> 64, in execute
>>>>>> django.db.utils.ProgrammingError: relation "django_site" does not
>>>>>> exist
>>>>>> LINE 1: SELECT (1) AS "a" FROM "django_site" LIMIT 1
>>>>>> then I run manage.py migrate sites:
>>>>>> WARNINGS:
>>>>>> provided.
>>>>>>   Apply all migrations: sites
>>>>>> Running migrations:
>>>>>>   Applying sites.0001_initial... OK
>>>>>>   File
>>>>>>     utility.execute()
>>>>>>   File
>>>>>>   File
>>>>>>   File
>>>>>>   File
>>>>>> line 226, in handle
>>>>>>   File
>>>>>>     using=db)
>>>>>>   File
>>>>>> line 189, in send
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/guardian/management/__init__.py",
>>>>>> line 32, in create_anonymous_user
>>>>>>     User.objects.get(pk=guardian_settings.ANONYMOUS_USER_ID)
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line
>>>>>> 127, in manager_method
>>>>>>     return getattr(self.get_queryset(), name)(*args, **kwargs)
>>>>>>   File
>>>>>> 328, in get
>>>>>>     num = len(clone)
>>>>>>   File
>>>>>> 144, in __len__
>>>>>>     self._fetch_all()
>>>>>>   File
>>>>>> 965, in _fetch_all
>>>>>>     self._result_cache = list(self.iterator())
>>>>>>   File
>>>>>> 238, in iterator
>>>>>>     results = compiler.execute_sql()
>>>>>>   File
>>>>>>   File
>>>>>> 79, in execute
>>>>>>   File
>>>>>> 64, in execute
>>>>>>   File
>>>>>> 64, in execute
>>>>>> django.db.utils.ProgrammingError: relation "people_profile" does not
>>>>>> exist
>>>>>> LINE 1: ...ofile"."zipcode", "people_profile"."country" FROM
>>>>>> "people_pr...
>>>>>> then manage.py migrate people:
>>>>>> WARNINGS:
>>>>>> provided.
>>>>>>   Apply all migrations: people
>>>>>> Running migrations:
>>>>>>   Applying taggit.0001_initial... OK
>>>>>>   Applying taggit.0002_auto_20150616_2121... OK
>>>>>>   Applying people.0001_initial... OK
>>>>>>   Applying people.0002_auto_20160623_0404... OK
>>>>>>   File
>>>>>>     utility.execute()
>>>>>>   File
>>>>>>   File
>>>>>>   File
>>>>>>   File
>>>>>> line 226, in handle
>>>>>>   File
>>>>>>     using=db)
>>>>>>   File
>>>>>> line 189, in send
>>>>>>   File
>>>>>> line 39, in create_anonymous_user
>>>>>>     user.save()
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line
>>>>>> 734, in save
>>>>>>     force_update=force_update, update_fields=update_fields)
>>>>>>   File
>>>>>> 771, in save_base
>>>>>>     update_fields=update_fields, raw=raw, using=using)
>>>>>>   File
>>>>>> line 189, in send
>>>>>>   File "/usr/local/lib/python2.7/dist-packages/account/models.py",
>>>>>> line 106, in user_post_save
>>>>>>     Account.create(user=user)
>>>>>> line 63, in create
>>>>>>     account.save()
>>>>>>   File
>>>>>> 734, in save
>>>>>>   File
>>>>>> 762, in save_base
>>>>>>     updated = self._save_table(raw, cls, force_insert, force_update,
>>>>>> using, update_fields)
>>>>>>   File
>>>>>> 846, in _save_table
>>>>>>     result = self._do_insert(cls._base_manager, using, fields,
>>>>>> update_pk, raw)
>>>>>>   File
>>>>>> 885, in _do_insert
>>>>>>     using=using, raw=raw)
>>>>>>   File
>>>>>>   File
>>>>>> 920, in _insert
>>>>>>     return query.get_compiler(using=using).execute_sql(return_id)
>>>>>>   File
>>>>>> line 974, in execute_sql
>>>>>>   File
>>>>>> 79, in execute
>>>>>>   File
>>>>>> 64, in execute
>>>>>>   File
>>>>>> 64, in execute
>>>>>> django.db.utils.ProgrammingError: relation "account_account" does not
>>>>>> exist
>>>>>> LINE 1: INSERT INTO "account_account" ("user_id", "timezone",
>>>>>> "langu...
>>>>>> then manage.py migrate:
>>>>>> WARNINGS:
>>>>>> provided.
>>>>>>   Synchronize unmigrated apps: tasks, dialogos, modeltranslation,
>>>>>> django_extensions, djcelery, polymorphic, agon_ratings, gis,
>>>>>> pinax_theme_bootstrap_account, django_forms_bootstrap, catalogue, humanize,
>>>>>> geoserver, announcements, storages, user_messages, mptt, friendlytagloader,
>>>>>> staticfiles, geoexplorer, sitemaps, proxy, account, pinax_theme_bootstrap,
>>>>>> pagination, autocomplete_light, messages, leaflet, api, avatar, social,
>>>>>> security
>>>>>>   Apply all migrations: layers, documents, actstream, people, admin,
>>>>>> guardian, sessions, sites, auth, tastypie, maps, contenttypes, base,
>>>>>> upload, groups, services, taggit
>>>>>> Synchronizing apps without migrations:
>>>>>>   Creating tables...
>>>>>>     Creating table celery_taskmeta
>>>>>>     Creating table celery_tasksetmeta
>>>>>>     Creating table djcelery_intervalschedule
>>>>>>     Creating table djcelery_crontabschedule
>>>>>>     Creating table djcelery_periodictasks
>>>>>>     Creating table djcelery_workerstate
>>>>>>     Creating table djcelery_taskstate
>>>>>>     Creating table account_account
>>>>>>     Creating table account_signupcode
>>>>>>     Creating table account_signupcodeextended
>>>>>>     Creating table account_signupcoderesult
>>>>>>     Creating table account_emailaddress
>>>>>>     Creating table account_emailconfirmation
>>>>>>     Creating table account_accountdeletion
>>>>>>     Creating table avatar_avatar
>>>>>>     Creating table dialogos_comment
>>>>>>     Creating table agon_ratings_overallrating
>>>>>>     Creating table agon_ratings_rating
>>>>>>     Creating table announcements_announcement
>>>>>>     Creating table announcements_dismissal
>>>>>>     Creating table user_messages_thread
>>>>>>     Creating table user_messages_userthread
>>>>>>     Creating table user_messages_message
>>>>>>     Running deferred SQL...
>>>>>>   Installing custom SQL...
>>>>>> Running migrations:
>>>>>>   Applying actstream.0001_initial... OK
>>>>>>   Applying admin.0001_initial... OK
>>>>>>   Applying base.0001_initial... OK
>>>>>>   Applying base.0002_topiccategory_fa_class... OK
>>>>>>   Applying base.0003_auto_20160623_0404... OK
>>>>>>   Applying documents.0001_initial... OK
>>>>>>   Applying groups.0001_initial... OK
>>>>>>   Applying guardian.0001_initial... OK
>>>>>>   Applying layers.0001_initial... OK
>>>>>>   Applying services.0001_initial... OK
>>>>>>   Applying layers.0002_initial_step2... OK
>>>>>>   Applying layers.0003_auto_20160623_0404... OK
>>>>>>   Applying maps.0001_initial... OK
>>>>>>   Applying services.0002_auto_20160623_0404... OK
>>>>>>   Applying sessions.0001_initial... OK
>>>>>>   Applying tastypie.0001_initial... OK
>>>>>>   Applying upload.0001_initial... OK
>>>>>> Is that ok? How/can I restore the dump file of my previous DBs?
>>>>>> Thanks
>>>>>> Eugenio
>>>>>> From: simone.dalmasso at gmail.com
>>>>>> Date: Thu, 23 Jun 2016 10:55:47 +0200
>>>>>> Subject: Re: [GeoNode-users] database update error
>>>>>> To: frippe12573 at hotmail.com
>>>>>> CC: geonode-users at lists.osgeo.org
>>>>>> Hi Eugenio,
>>>>>> beware that the data model and django version is changed in master.
>>>>>> This issue happens when using postgres as db and not sqllite. At the moment
>>>>>> the way to create the new db is by doing
>>>>>> manage.py migrate
>>>>>> We will fix this in the future.
>>>>>> 2016-06-23 10:27 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com
>>>>>> Hi all,
>>>>>> today I was trying to update geonode from git (custom installation on
>>>>>> ubuntu 14.04).
>>>>>> I made a backup of the data from geonode and geonode_data db, then I
>>>>>> created new DBs,
>>>>>> and I run syncdb --noinput, but something seems not working:
>>>>>> WARNINGS:
>>>>>> provided.
>>>>>> django_extensions, polymorphic, agon_ratings, gis,
>>>>>> security
>>>>>> guardian, sessions, djcelery, sites, auth, tastypie, maps, contenttypes,
>>>>>> base, upload, groups, services, taggit
>>>>>>   Creating tables...
>>>>>>   File
>>>>>>     utility.execute()
>>>>>>   File
>>>>>>   File
>>>>>>   File
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/syncdb.py",
>>>>>> line 25, in handle
>>>>>>     call_command("migrate", **options)
>>>>>>   File
>>>>>> line 120, in call_command
>>>>>>     return command.execute(*args, **defaults)
>>>>>>   File
>>>>>>   File
>>>>>> line 179, in handle
>>>>>>     created_models = self.sync_apps(connection,
>>>>>> executor.loader.unmigrated_apps)
>>>>>>   File
>>>>>> line 318, in sync_apps
>>>>>>     cursor.execute(statement)
>>>>>>   File
>>>>>> 79, in execute
>>>>>>   File
>>>>>> 64, in execute
>>>>>>   File
>>>>>> 62, in execute
>>>>>>     return self.cursor.execute(sql)
>>>>>> exist
>>>>>> Of course I performed the update of the dbs after run git pull on
>>>>>> geonode dir.
>>>>>> Can you help me?
>>>>>> Eugenio
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>> Simone
>>>> Simone
>>> Simone
>> Simone
> *Best Regards *
> *M. Farhan-Ul-Moazzam*
> *BS(Hons) Geomatics (GIS/RS)*
> *Research Associate *
> *Alkhidmat Disaster Management Center*
> *Cell# : +923139779248*
> *E-mail: farhan.moazzam at gmail.com
> <javascript:_e(%7B%7D,'cvml','farhan.moazzam at gmail.com');> *
> *           farhanpf1525 at hotmail.com
> <javascript:_e(%7B%7D,'cvml','farhanpf1525 at hotmail.com');>*
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160628/2cbecc18/attachment-0001.html>
More information about the geonode-users mailing list
