[GeoNode-users] Error saving style back to server
Daniel Victoria daniel.victoria at gmail.com
Tue Jun 28 08:20:16 PDT 2016
So, we've not been able to sort out this problem with a certificate that is
not matching our site. And since the guys that keep the network running
here do not know much about geonode/geoserver, we are a bit lost. Are there
any special configurations needed in order for GeoNode to play nice with
SSL certificates?
We found this doc online
http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/ssl.html
But it mentions Tomcat6 and some directories that are not present in my
GeoNode install, like /var/lib/tomcat6/webapps/geoserver/WEB-INF/web.xml
I'm running geonode 2.4 in Ubuntu 14.04, installed using the apt-get command
My site uses a SSL certificate from Let's Encrypt
Thanks
Daniel
On Wed, Jun 22, 2016 at 8:54 AM, Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> Just an update. I checked the same thing on an internal test server that I
> have (that I believe does not uses https) and I don't get the server error.
> So it's probably the hostname mismatch thing that is preventing me to
> change the layer style. Will talk to the network guys and hope they know
> how to fix it.
> cheers
> Daniel
> On Wed, Jun 22, 2016 at 8:34 AM, Daniel Victoria <
> daniel.victoria at gmail.com> wrote:
>> Hi Simone,
>> Thanks for the tip. Looking at the apache2.log it appears that it's some
>> problem with a cerificateHostnameMismatch. Am I reading the log correct?
>> I'll talk to the people that maintains out network and see about this
>> certificate.
>> On the same topic, in local_setting.py what should I put in SITEURL. The
>> actual name of my virtual machine (some funny thing like dmzv014)? Or the
>> name it's known in the internet (https://www.some.pretty.name.here)
>> Thanks
>> Daniel
>> On Wed, Jun 22, 2016 at 6:41 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi, take a look at the apache logs when the 500 error code appears, they
>>> should tell you more.
>>> 2016-06-21 20:12 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>>> Hi list,
>>>> I have a GeoNode instance running on Ubuntu, installed via
>>>> apt-get.Everything appears to be working fine however, when I try to change
>>>> a layer style, I get the error: "There was an error saving the style
>>>> back to the server."
>>>> Looking at the development console, I see that when I try to alter the
>>>> layer style there are 2 PUT calls to the server. The first one fails with
>>>> error 500 Internal server error. This is the call that's sending the SLD to
>>>> the server. The second one returns 200 OK and it's sending the a JSON
>>>> {"layer":{"defaultStyle":{"name":"estados"},"styles":{},"enabled":true}}
>>>> I'm trying to debug this error but can't find what is going on. I'm
>>>> running behind a proxy server. Could this be a security setting? Is it
>>>> normal that one PUT call fails and the other works?
>>>> Thanks
>>>> Daniel
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160628/eb437f7f/attachment-0001.html>
More information about the geonode-users mailing list
