[GeoNode-users] Error saving style back to server
Daniel Victoria daniel.victoria at gmail.com
Tue Jun 28 10:38:47 PDT 2016
Francesco,
I believe the site certificate is OK. At least the only security complain I
get when I load the site is that some images were loaded through an
insecure connection. The public address of the site is
www.paisagenslidar.cnptia.embrapa.br
baseurl is set to https://www.paisagenslidar.cnptia.embrapa.br/
One thing I noticed is that I'm getting the same error when I try to upload
a layer. Geonode will show me the error in the layer upload page. But the
layer gets registered in GeoServer...
[image: Inline image 1]
On Tue, Jun 28, 2016 at 2:22 PM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Daniel,
> I took a look at you apache log file and the message is an hostname
> mismatching so I presume that’s something wrong in the subject of the
> certificate. Are you sure that your servername is the hostname used for the
> subject? And what did you set as baseurl?
> F.
> Il giorno 28/giu/2016, alle ore 18:33, Daniel Victoria <
> daniel.victoria at gmail.com> ha scritto:
> Hi Francesco,
> Thanks for the help. Just to clarify, what should I place in
> /usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml?
> <BaseUrl> was set to http://localhost/. I changed to my site URL,
> restarted tomcat7 & apache, but it did not change anything.
> Cheers
> Daniel
> On Tue, Jun 28, 2016 at 1:00 PM, Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Hi Daniel,
>> the SSL configuration is due just on the geonode virtual host of Apache
>> web server where GeoServer is proxy passed. So nothing special than a
>> standard SSL apache configuration. Actually GeoServer with the release 2.4
>> is deployed under Tomcat 7 so you should have a look there.
>> For instance to configure the geonode base url you can edit this file in
>> ubuntu:
>> Francesco
>> Il giorno 28/giu/2016, alle ore 17:20, Daniel Victoria <
>> So, we've not been able to sort out this problem with a certificate that
>> is not matching our site. And since the guys that keep the network running
>> here do not know much about geonode/geoserver, we are a bit lost. Are there
>> any special configurations needed in order for GeoNode to play nice with
>> SSL certificates?
>> We found this doc online
>> http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/ssl.html
>> But it mentions Tomcat6 and some directories that are not present in my
>> GeoNode install, like /var/lib/tomcat6/webapps/geoserver/WEB-INF/web.xml
>> I'm running geonode 2.4 in Ubuntu 14.04, installed using the apt-get
>> command.
>> My site uses a SSL certificate from Let's Encrypt
>> Thanks
>> Daniel
>> On Wed, Jun 22, 2016 at 8:54 AM, Daniel Victoria <
>> daniel.victoria at gmail.com> wrote:
>>> Just an update. I checked the same thing on an internal test server that
>>> I have (that I believe does not uses https) and I don't get the server
>>> error. So it's probably the hostname mismatch thing that is preventing me
>>> to change the layer style. Will talk to the network guys and hope they know
>>> how to fix it.
>>> cheers
>>> Daniel
>>> On Wed, Jun 22, 2016 at 8:34 AM, Daniel Victoria <
>>>> Hi Simone,
>>>> Thanks for the tip. Looking at the apache2.log it appears that it's
>>>> some problem with a cerificateHostnameMismatch. Am I reading the log
>>>> correct? I'll talk to the people that maintains out network and see about
>>>> this certificate.
>>>> On the same topic, in local_setting.py what should I put in SITEURL.
>>>> The actual name of my virtual machine (some funny thing like dmzv014)? Or
>>>> the name it's known in the internet (https://www.some.pretty.name.here)
>>>> Thanks
>>>> Daniel
>>>> On Wed, Jun 22, 2016 at 6:41 AM, Simone Dalmasso <
>>>> simone.dalmasso at gmail.com> wrote:
>>>>> Hi, take a look at the apache logs when the 500 error code appears,
>>>>> they should tell you more.
>>>>> 2016-06-21 20:12 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>
>>>>>> Hi list,
>>>>>> I have a GeoNode instance running on Ubuntu, installed via
>>>>>> apt-get.Everything appears to be working fine however, when I try to change
>>>>>> a layer style, I get the error: "There was an error saving the style
>>>>>> back to the server."
>>>>>> Looking at the development console, I see that when I try to alter
>>>>>> the layer style there are 2 PUT calls to the server. The first one fails
>>>>>> with error 500 Internal server error. This is the call that's sending the
>>>>>> SLD to the server. The second one returns 200 OK and it's sending the a
>>>>>> JSON
>>>>>> {"layer":{"defaultStyle":{"name":"estados"},"styles":{},"enabled":true}}
>>>>>> I'm trying to debug this error but can't find what is going on. I'm
>>>>>> running behind a proxy server. Could this be a security setting? Is it
>>>>>> normal that one PUT call fails and the other works?
>>>>>> Thanks
>>>>>> Daniel
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160628/e5b5c95a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160628/e5b5c95a/attachment-0001.png>
More information about the geonode-users mailing list
