[GeoNode-users] No route to host
Israel López asralf at gmail.com
Tue Jun 28 12:49:19 PDT 2016
Hi Francesco well I had a previous geonode 2.4 version, so I decided only
upgrade the code.
No, I get it from 2.4.x branch in github.
The problem began when we migrate the local IP address to a Public IP.
Any idea to look for?
2016-06-28 14:04 GMT-05:00 Francesco Bartoli <xbartolone at gmail.com>:
> Did you get geonode from apt-get? Why are you running GS 2.5.1 while GN
> 2.4 is shipped with 2.7.4?
> However the error looks like related to some firewall rule that is
> blocking your request.
> Francesco
> Il giorno 28/giu/2016, alle ore 20:26, Israel López <asralf at gmail.com> ha
> scritto:
> Good day dear devs, I'm having troubles with upload
> a shape file in a production environment, the apache
> error.log is:
> [Tue Jun 28 13:13:32.341541 2016] [:error] [pid 9762:tid 139855292634880]
> [Errno 113] No route to host
> [Tue Jun 28 13:13:32.341647 2016] [:error] [pid 9762:tid 139855292634880]
> Traceback (most recent call last):
> [Tue Jun 28 13:13:32.341656 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/var/www/html/idegeo24/geonode/layers/views.py", line 166, in
> layer_upload
> [Tue Jun 28 13:13:32.341664 2016] [:error] [pid 9762:tid 139855292634880]
>     title=form.cleaned_data["layer_title"],
> [Tue Jun 28 13:13:32.341670 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/var/www/html/idegeo24/geonode/layers/utils.py", line 470, in
> file_upload
> [Tue Jun 28 13:13:32.341677 2016] [:error] [pid 9762:tid 139855292634880]
>     defaults=defaults
> [Tue Jun 28 13:13:32.341683 2016] [:error] [pid 9762:tid 139855292634880]
>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line
> 154, in get_or_create
> [Tue Jun 28 13:13:32.341690 2016] [:error] [pid 9762:tid 139855292634880]
>     return self.get_queryset().get_or_create(**kwargs)
> [Tue Jun 28 13:13:32.341696 2016] [:error] [pid 9762:tid 139855292634880]
>   File
> "/usr/local/lib/python2.7/dist-packages/modeltranslation/manager.py", line
> 341, in get_or_create
> [Tue Jun 28 13:13:32.341703 2016] [:error] [pid 9762:tid 139855292634880]
>     return super(MultilingualQuerySet, self).get_or_create(**kwargs)
> [Tue Jun 28 13:13:32.341709 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py",
> line 383, in get_or_create
> [Tue Jun 28 13:13:32.341716 2016] [:error] [pid 9762:tid 139855292634880]
>     obj.save(force_insert=True, using=self.db)
> [Tue Jun 28 13:13:32.341722 2016] [:error] [pid 9762:tid 139855292634880]
>   File
> "/usr/local/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py",
> line 90, in save
> [Tue Jun 28 13:13:32.341729 2016] [:error] [pid 9762:tid 139855292634880]
>     return super(PolymorphicModel, self).save(*args, **kwargs)
> [Tue Jun 28 13:13:32.341735 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py",
> line 545, in save
> [Tue Jun 28 13:13:32.341741 2016] [:error] [pid 9762:tid 139855292634880]
>     force_update=force_update, update_fields=update_fields)
> [Tue Jun 28 13:13:32.341748 2016] [:error] [pid 9762:tid 139855292634880]
> line 569, in save_base
> [Tue Jun 28 13:13:32.341754 2016] [:error] [pid 9762:tid 139855292634880]
> [Tue Jun 28 13:13:32.341760 2016] [:error] [pid 9762:tid 139855292634880]
>   File
> "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py",
> line 185, in send
> [Tue Jun 28 13:13:32.341767 2016] [:error] [pid 9762:tid 139855292634880]
>     response = receiver(signal=self, sender=sender, **named)
> [Tue Jun 28 13:13:32.341773 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/var/www/html/idegeo24/geonode/geoserver/signals.py", line 74, in
> geoserver_pre_save
> [Tue Jun 28 13:13:32.341779 2016] [:error] [pid 9762:tid 139855292634880]
>     charset=instance.charset)
> [Tue Jun 28 13:13:32.341785 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/var/www/html/idegeo24/geonode/geoserver/helpers.py", line 1190, in
> geoserver_upload
> [Tue Jun 28 13:13:32.341807 2016] [:error] [pid 9762:tid 139855292634880]
>     sld = get_sld_for(publishing)
> [Tue Jun 28 13:13:32.341813 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/var/www/html/idegeo24/geonode/geoserver/helpers.py", line 189, in
> get_sld_for
> [Tue Jun 28 13:13:32.341818 2016] [:error] [pid 9762:tid 139855292634880]
>     name = layer.default_style.name if layer.default_style is not None
> else "point"
> [Tue Jun 28 13:13:32.341824 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/usr/local/lib/python2.7/dist-packages/geoserver/layer.py", line
> 103, in _get_default_style
> [Tue Jun 28 13:13:32.341830 2016] [:error] [pid 9762:tid 139855292634880]
>     return self._resolve_style(element) if element is not None else None
> [Tue Jun 28 13:13:32.341835 2016] [:error] [pid 9762:tid 139855292634880]
> 111, in _resolve_style
> [Tue Jun 28 13:13:32.341841 2016] [:error] [pid 9762:tid 139855292634880]
>     return self.catalog.get_style_by_url(style_workspace_url)
> [Tue Jun 28 13:13:32.341846 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/usr/local/lib/python2.7/dist-packages/geoserver/catalog.py", line
> 798, in get_style_by_url
> [Tue Jun 28 13:13:32.341851 2016] [:error] [pid 9762:tid 139855292634880]
>     dom = self.get_xml(style_workspace_url)
> [Tue Jun 28 13:13:32.341857 2016] [:error] [pid 9762:tid 139855292634880]
> 211, in get_xml
> [Tue Jun 28 13:13:32.341862 2016] [:error] [pid 9762:tid 139855292634880]
>     response, content = self.http.request(rest_url)
> [Tue Jun 28 13:13:32.341867 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1569,
> in request
> [Tue Jun 28 13:13:32.341873 2016] [:error] [pid 9762:tid 139855292634880]
>     (response, content) = self._request(conn, authority, uri, request_uri,
> method, body, headers, redirections, cach$
> [Tue Jun 28 13:13:32.341879 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1316,
> in _request
> [Tue Jun 28 13:13:32.341885 2016] [:error] [pid 9762:tid 139855292634880]
>     (response, content) = self._conn_request(conn, request_uri, method,
> body, headers)
> [Tue Jun 28 13:13:32.341890 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1289,
> in _conn_request
> [Tue Jun 28 13:13:32.341895 2016] [:error] [pid 9762:tid 139855292634880]
>     conn.connect()
> [Tue Jun 28 13:13:32.341901 2016] [:error] [pid 9762:tid 139855292634880]
>   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 912,
> in connect
> [Tue Jun 28 13:13:32.341906 2016] [:error] [pid 9762:tid 139855292634880]
>     raise socket.error, msg
> [Tue Jun 28 13:13:32.341911 2016] [:error] [pid 9762:tid 139855292634880]
> error: [Errno 113] No route to host
> I'm running Geoserver 2.5.1 with geonode 2.4, I don't know if this could
> be the trouble.
> Any advice is welcome.
> Thank you in advance.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160628/43660739/attachment.html>
More information about the geonode-users mailing list
