[GeoNode-users] importing private layer creates a public layer
Paolo Corti pcorti at gmail.com
Tue Mar 1 06:59:11 PST 2016
I think you could use the general Django permission systems, and remove the
"maps | map | can add map" permission from a user or a group of user
You will also need to customize the template in order to disable this
feature from the user interface
p
On Tue, Mar 1, 2016 at 3:46 AM, Carmine Massarelli <
carmine.massarelli at ba.irsa.cnr.it> wrote:
> Yes to all,
> in addiction I report that if I try to print the layer with the print tool
> the layer disappear (as it should be for a protected layer).
> I use geonode version 2.4b25 on Ubuntu server 14.04.
> I am opening a ticket on github.
> Is it possible (at the moment) to prevent other user to create map?
> Thanks
> Carmine
> Il 02/29/2016 09:30 PM, Paolo Corti ha scritto:
> If I understand correctly:
> * you set a layer as not being downloadable using the "Set permissions"
> form in the layer page
> * the layer details page correctly does not display the "Download layer"
> button
> * clicking on the "Download map" button in the map details page you will
> get that layer in the download zip file
> If confirmed, it is a bug, so please file a ticket in github.
> Having said so, please consider that even after fixing the bug (pretty
> easy in this case) at this time the layer download permissions are honored
> only by the GeoNode Django interface, and not by GeoServer:
> https://github.com/GeoNode/geonode/issues/2085
> best
> p
> On Mon, Feb 29, 2016 at 1:44 PM, Carmine Massarelli <
> <carmine.massarelli at ba.irsa.cnr.it>carmine.massarelli at ba.irsa.cnr.it>
> wrote:
>> thanks for the reply but unfortunately does not solve the problem.
>> The layer is set only in display mode but if a user creates a map with
>> this layer and clicks on the map download he can download the layer zip
>> file. I made ​​only changes in settings.py about allowed hosts, the user
>> belongs to a group. In a WM duplicate of the platform I get a warning that
>> says that you can not download the layer for safety reasons, while in the
>> published version on the web there is no such notice. What could be related?
>> Thank you
>> Carmine
>> Il 28/02/2016 08:45, Simone Dalmasso ha scritto:
>> Hi, you can set whether a new layer is public or not by changing those
>> two settings here
>> <https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L405>
>> Hope it helps
>> 2016-02-28 0:05 GMT+01:00 Carmine Massarelli <
>> <carmine.massarelli at ba.irsa.cnr.it>carmine.massarelli at ba.irsa.cnr.it>:
>>> Dear,
>>> how can I avoid this: when I upload a private layer (no edit and no
>>> download permitted, only view and query) another user is able to download
>>> it by creating a new public map with this layer. Is there a way to prevent
>>> other users from creating maps or downloading private layer if imported in
>>> other maps?
>>> Regards
>>> Carmine
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160301/7d5c5f9c/attachment.html>
More information about the geonode-users mailing list
