[GeoNode-users] FW: info table on Identify
Eugenio Trumpy frippe12573 at hotmail.com
Fri Mar 4 04:32:44 PST 2016
just to understand a bit more, the place to work on info table format is the GeoExplorer.js
/geonode/geonode/static_root/geoexplorer/script/
or something different?
E.
Date: Thu, 3 Mar 2016 20:20:31 +0100
Subject: Re: [GeoNode-users] FW: info table on Identify
To: frippe12573 at hotmail.com
CC: geonode-users at lists.osgeo.org
Hi, this is too specific question and I can't answer. Any other opinions?
2016-03-03 9:45 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
Hi Simone and all,
I solved by using a solution quite close to your first suggestion:
my layer actually is a postgis view published by a different geoserver in my institution,
I only make a query for the postgis view which add a field built as concat of a string series where inside I concatenated the values from a field
belong to the same view. The field in the spatial view has an HTML format, so changing the info/format in the layer properties I can see the link.
I would have a more question on info table format:
I know that the HTML works only for text/html format that produce an horizontal info table.
Actually the text/plain produce a vertical info table, which it looks like more nice than the horizontal one.
Is it possible to maintain a vertical info table that use a text/html format?
best
Eugenio
Date: Tue, 1 Mar 2016 20:03:42 +0100
Subject: Re: [GeoNode-users] info table on Identify
Eugenio,
I see two options, the "most" feasible would be to customise the way geonode inserts the data into the database so that he stores what you need. I thing that gsconfig is the place where you could act.
The second would be to customise the output, so to build the url on the geoexplorer side, and you would have to customise it.
Both of them might be challenging.
2016-03-01 18:29 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
Hi all,
I followed sometime ago this post:
https://groups.google.com/forum/#!topic/geonode-users/_70X3r03Pt4
on
 displaying a url in a field of the table got from 'getfeatureinfo'
(i.e. Identify button on GeoExplorer (i.e. Maps function of geonode)).
I tested the solution and actually it works, I would add 'statically'.
I mean I can run the link to an external document or somehow as the link stored in the field is.
I wonder if it is possible to build a URL dynamically, and store it in the output table of the getfeatureinfo.
I try to make an example:
consider a map with only one point layer, the layer has a simple table of attributes (id, name, url)
on identify I get info from a feature and in output table I have id, name and url of course, what I'm asking
you is if it is possible to complete the url inserting the value of the identified feature.
If I identify a feature with id=300 name=pippo and url=http://my_server_name/srt/chart.php?id=
It would be nice to have url completed as follow dinamically
http://my_server_name/srt/chart.php?id=300
Is that feasible?
Thank you for any react
best
Eugenio
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160304/3ec57939/attachment.html>
More information about the geonode-users mailing list
