[GeoNode-users] Setup for theming GeoNode with CentOS7
Côté, Kevin Kevin.Cote at wspgroup.com
Thu Mar 10 05:54:14 PST 2016
I have a brand new GeoNode working on CentOS7. I want to customize the theme of the app, so I follow the setup steps found here : http://docs.geonode.org/en/stable/tutorials/admin/customize_lookfeel/customize/setup_admin.html#setup-admin
Problem is, the command "$ django-admin " is not found when I try to run it in a new folder.
Is it only possible to do that with Ubuntu ?
Thank for your tips !
Kevin
You are receiving this communication because you are listed as a current WSP contact. Should you have any questions regarding WSP's electronic communications policy, please consult our Anti-Spam Commitment www.wspgroup.com/casl. For any concern or if you believe you should not be receiving this message, please forward this message to caslcompliance at wspgroup.com so that we can promptly address your request. This message is intended only for the addressee and may contain information which is privileged, confidential, proprietary, or exempt from disclosure under applicable law. If you are not the intended recipient, you are strictly prohibited from disclosing, distributing, copying, or in any way using this message. If you have received this communication in error, please notify the sender and delete any copies you may have received. WSP's Land Surveying entities in AB and BC are WSP Surveys (AB) Limited Partnership and WSP Surveys (BC) Limited Partnership.
Vous recevez cette communication car vous faites partie des contacts de WSP. Si vous avez des questions concernant la politique de communications électroniques de WSP, veuillez consulter notre Engagement anti-pourriel www.wspgroup.com/lcap. Pour toute question ou si vous croyez que vous ne devriez pas recevoir ce message, prière de le transférer au conformitelcap at wspgroup.com afin que nous puissions rapidement traiter votre demande. Ce message est destiné uniquement au destinataire et il peut contenir des informations privilégiées, confidentielles ou non divulgables en vertu de la loi. Si vous n'êtes pas le destinataire du présent message, il vous est strictement interdit de le divulguer, de le distribuer, de le copier ou de l'utiliser de quelque façon que ce soit. Si vous avez reçu la présente communication par erreur, veuillez en aviser l'expéditeur et supprimer le message.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160310/599f5808/attachment.html>
More information about the geonode-users mailing list
