[GeoNode-users] GeoSites Deploy
Brian Norberg bnorberg02 at gmail.com
Fri Mar 11 06:05:12 PST 2016
I am interested in testing GeoNode GeoSites and was wondering if there are
any best practices for installing a multisite setup. Right now, I have a
quick installation of GeoNode 2.4 on Ubuntu,
http://docs.geonode.org/en/master/tutorials/install_and_admin/quick_install.html.
Can you use the manage.py addsite command in the quick installation setup?
If so, what directory should I run the management command, and does it need
to be done as root?
I also notice this repo for creating multisite GeoNode,
https://github.com/terranodo/landscapeportal. Is this the more preferred
method for doing a multisite setup?
Thank you for you time.
Brian
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160311/4ddd7a89/attachment.html>
More information about the geonode-users mailing list
