[GeoNode-users] Issue with imported SLD (1.1.0) files produced by QGIS (2.14)
Daniel Victoria daniel.victoria at gmail.com
Mon Mar 14 12:22:43 PDT 2016
Hi Kevin,
What I found is that if I copy the SLD from QGis straight into GeoServer,
it works. However, if you try to edit the style using the GeoNode style
dialog, the file gets corrupted.
Cheers
Daniel
On Mon, Mar 14, 2016 at 2:59 PM, Kevin Côté <Kevin.Cote2 at usherbrooke.ca>
wrote:
> Hi,
> I'm trying to import a SLD file alongside the common shapefiles files. My
> SLD files are generated by the Style Editor of QGIS 2.14, therefore they
> are in SLD 1.1.0 format.
> When imported into GeoNode and shown in the GeoServer style editor, it
> looks like the SLD file is converted back to 1.0.0 and therefore loses some
> parameters (in my case, I'm losing color attributes).
> From what I've found, it looks like GeoNode only accepts 1.0.0 SLD files.
> Is it true ? Is there a way that I can make GeoNode work with QGIS exported
> SLD files ?
> Thanks for your help !
> Kevin
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160314/e0d07457/attachment.html>
More information about the geonode-users mailing list
