[GeoNode-users] Error creating style from GeoExplorer
Simone Dalmasso simone.dalmasso at gmail.com
Fri Mar 18 06:01:55 PDT 2016
Strange, seems that the layer for which you are creating the style doesn't
exists.
Is it a local layer from geonode?
2016-03-18 13:26 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi,
> I've suddenly received an error when creating an style from GeoExplorer
> view.
> [Fri Mar 18 13:03:40.424495 2016] [:error] [pid 11513:tid
> 139855235708672] Internal Server Error: /gs/rest/styles
> [Fri Mar 18 13:03:40.424527 2016] [:error] [pid 11513:tid 139855235708672]
> Traceback (most recent call last):
> [Fri Mar 18 13:03:40.424532 2016] [:error] [pid 11513:tid
> 139855235708672]   File
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 112,
> in get_response
> [Fri Mar 18 13:03:40.424536 2016] [:error] [pid 11513:tid
> 139855235708672]     response = wrapped_callback(request, *callback_args,
> **callback_kwargs)
> [Fri Mar 18 13:03:40.424540 2016] [:error] [pid 11513:tid
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/views.py", line
> 339, in geoserver_rest_proxy
> [Fri Mar 18 13:03:40.424544 2016] [:error] [pid 11513:tid
> 139855235708672]     style_update(request, url)
> [Fri Mar 18 13:03:40.424548 2016] [:error] [pid 11513:tid
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
> 1509, in style_update
> [Fri Mar 18 13:03:40.424552 2016] [:error] [pid 11513:tid
> 139855235708672]     layer =
> Layer.objects.all().filter(typename=layer_name)[0]
> [Fri Mar 18 13:03:40.424555 2016] [:error] [pid 11513:tid
> "/usr/lib/python2.7/dist-packages/django/db/models/query.py", line 132, in
> __getitem__
> [Fri Mar 18 13:03:40.424559 2016] [:error] [pid 11513:tid
> 139855235708672]     return list(qs)[0]
> [Fri Mar 18 13:03:40.424563 2016] [:error] [pid 11513:tid 139855235708672]
> IndexError: list index out of range
> [Fri Mar 18 13:03:40.590121 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818] mod_wsgi (pid=11513): Exception occurred
> processing WSGI script '/var/www/geonode/wsgi/geonode.wsgi'.
> [Fri Mar 18 13:03:40.590177 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818] Traceback (most recent call last):
> [Fri Mar 18 13:03:40.590204 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818]   File
> "/usr/lib/python2.7/dist-packages/django/core/handlers/wsgi.py", line 206,
> in __call__
> [Fri Mar 18 13:03:40.590367 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818]     response = self.get_response(request)
> [Fri Mar 18 13:03:40.590392 2016] [:error] [pid 11513:tid 139855235708672]
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 194,
> in get_response
> [Fri Mar 18 13:03:40.590420 2016] [:error] [pid 11513:tid 139855235708672]
> self.handle_uncaught_exception(request, resolver, sys.exc_info())
> [Fri Mar 18 13:03:40.590433 2016] [:error] [pid 11513:tid 139855235708672]
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 236,
> in handle_uncaught_exception
> [Fri Mar 18 13:03:40.590463 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818]     return callback(request, **param_dict)
> [Fri Mar 18 13:03:40.590478 2016] [:error] [pid 11513:tid 139855235708672]
> "/usr/lib/python2.7/dist-packages/django/utils/decorators.py", line 99, in
> _wrapped_view
> [Fri Mar 18 13:03:40.590556 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818]     response = view_func(request, *args,
> **kwargs)
> [Fri Mar 18 13:03:40.590575 2016] [:error] [pid 11513:tid 139855235708672]
> "/usr/lib/python2.7/dist-packages/django/views/defaults.py", line 46, in
> server_error
> [Fri Mar 18 13:03:40.590638 2016] [:error] [pid 11513:tid 139855235708672]
> http.HttpResponseServerError(template.render(Context({})))
> [Fri Mar 18 13:03:40.590655 2016] [:error] [pid 11513:tid 139855235708672]
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 140, in
> render
> [Fri Mar 18 13:03:40.590978 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818]     return self._render(context)
> [Fri Mar 18 13:03:40.590995 2016] [:error] [pid 11513:tid 139855235708672]
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in
> _render
> [Fri Mar 18 13:03:40.591015 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818]     return self.nodelist.render(context)
> [Fri Mar 18 13:03:40.591029 2016] [:error] [pid 11513:tid 139855235708672]
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in
> render
> [Fri Mar 18 13:03:40.591045 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818]     bit = self.render_node(node, context)
> [Fri Mar 18 13:03:40.591055 2016] [:error] [pid 11513:tid 139855235708672]
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in
> render_node
> [Fri Mar 18 13:03:40.591070 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818]     return node.render(context)
> [Fri Mar 18 13:03:40.591083 2016] [:error] [pid 11513:tid 139855235708672]
> "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 53,
> in render
> [Fri Mar 18 13:03:40.591187 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818]     result = self.nodelist.render(context)
> [Fri Mar 18 13:03:40.591202 2016] [:error] [pid 11513:tid 139855235708672]
> render
> [Fri Mar 18 13:03:40.591220 2016] [:error] [pid 11513:tid 139855235708672]
> [Fri Mar 18 13:03:40.591231 2016] [:error] [pid 11513:tid 139855235708672]
> render_node
> [Fri Mar 18 13:03:40.591246 2016] [:error] [pid 11513:tid 139855235708672]
> [Fri Mar 18 13:03:40.591257 2016] [:error] [pid 11513:tid 139855235708672]
> 155, in render
> [Fri Mar 18 13:03:40.591271 2016] [:error] [pid 11513:tid 139855235708672]
> self.render_template(self.template, context)
> [Fri Mar 18 13:03:40.591282 2016] [:error] [pid 11513:tid 139855235708672]
> 137, in render_template
> [Fri Mar 18 13:03:40.591296 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818]     output = template.render(context)
> [Fri Mar 18 13:03:40.591306 2016] [:error] [pid 11513:tid 139855235708672]
> render
> [Fri Mar 18 13:03:40.591328 2016] [:error] [pid 11513:tid 139855235708672]
> [Fri Mar 18 13:03:40.591339 2016] [:error] [pid 11513:tid 139855235708672]
> _render
> [Fri Mar 18 13:03:40.591353 2016] [:error] [pid 11513:tid 139855235708672]
> [Fri Mar 18 13:03:40.591363 2016] [:error] [pid 11513:tid 139855235708672]
> render
> [Fri Mar 18 13:03:40.591378 2016] [:error] [pid 11513:tid 139855235708672]
> [Fri Mar 18 13:03:40.591388 2016] [:error] [pid 11513:tid 139855235708672]
> render_node
> [Fri Mar 18 13:03:40.591402 2016] [:error] [pid 11513:tid 139855235708672]
> [Fri Mar 18 13:03:40.591415 2016] [:error] [pid 11513:tid 139855235708672]
> "/usr/lib/python2.7/dist-packages/announcements/templatetags/announcements_tags.py",
> line 24, in render
> [Fri Mar 18 13:03:40.591469 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818]     request = context["request"]
> [Fri Mar 18 13:03:40.591485 2016] [:error] [pid 11513:tid 139855235708672]
> "/usr/lib/python2.7/dist-packages/django/template/context.py", line 56, in
> __getitem__
> [Fri Mar 18 13:03:40.591558 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818]     raise KeyError(key)
> [Fri Mar 18 13:03:40.591587 2016] [:error] [pid 11513:tid 139855235708672]
> [remote 192.168.1.65:38818] KeyError: 'request'
> I've changed the grants as suggested here but without success
> https://lists.osgeo.org/pipermail/geonode-users/2015-May/000353.html
> Any ideas?
> Thanks in advance,
> Rehards,
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> *********************  LEGE OHARRA   *******************   AVISOLEGAL
> *******************   DISCLAIMER   *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160318/3d8d6f8a/attachment.html>
More information about the geonode-users mailing list
