[GeoNode-users] Upload problem
Simone Dalmasso simone.dalmasso at gmail.com
Mon May 2 06:06:35 PDT 2016
Ok,
could you take a look at the geoserver log to see if there are mentions on
why it's taking so long to process? Also, on the browser, with the
developers tools see the result of the http request when you upload the
layer.
Let us know
2016-05-02 15:04 GMT+02:00 Alessio <alessio.dl at gmail.com>:
> Hi Simone,
> Thank you for the answer.
> I think it's not my case: the layer is only 158 kb and my server is quite
> good. In the past I have uploaded data of various mb...
> Alessio
> Questa email é inviata da mobile, scusami per la brevità e gli errori
> Il giorno 02/mag/2016, alle ore 13:43, Simone Dalmasso <
> simone.dalmasso at gmail.com> ha scritto:
> Hi Alessio,
> could it be that your layer is big and the server is not enough powerful?
> 2016-05-02 13:01 GMT+02:00 Alessio <alessio.dl at gmail.com>:
>> Hi guys,
>> I have Geonode 2.0, installed  using APT on Ubuntu 12.04.4 LTS. My
>> problem is the following:
>> when I try to upload a shapefile, the loading bar fills completely but it
>> remains green and "fixed" until I receive a time out message.
>> If I then check the Geonode portal the layer is not present, but looking
>> at Geoserver, the layer is there and it works (the preview is visible).
>> How to fix this?
>> Thanks!
>> Alessio
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160502/a6c620c0/attachment.html>
More information about the geonode-users mailing list
