[GeoNode-users] Upload problem
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue May 3 02:43:36 PDT 2016
Hi all,
I don't think that the exception on the geoserver logs is the real issue.
It is just a warning from GWC, but since the layer works and the preview is
visible, on GeoServer side everything should be fine.
My guess is that an address resolution issue. Maybe in the
local_settings.py you have specified a GeoServer URL not reachable from the
client side.
This usually happens when writing, for instance, http://localhost/geoserver
>From the backend or the same server there are no issues, but whenever you
try to upload a layer from outside, your client won't be able to reach that
URL.
Can you please send us your local_settings? (DO NOT FORGET TO REMOVE OR
OBFUSCATE THE PASSWORDS AND URLs)
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Tue, May 3, 2016 at 10:56 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> ok so it has permissions. Then the issue is something else.
> maybe @afabiani has some hints.
> 2016-05-03 10:49 GMT+02:00 Alessio <alessio.dl at gmail.com>:
>> 2016-05-03 10:42 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Just check that he doesn't have the permissions yet so we are sure that
>>> that's the issue.
>> ​This is the permission settings for the "/tmp/tomcat7-tomcat7-tmp" folder
>> drwxr-xr-x 3 tomcat7 tomcat7 4096 May  2 12:44 Geotools
>> drwxr-xr-x 3 tomcat7 tomcat7 4096 May  2 12:44 geowebcache
>> ​and for the "geowebcache" subfolder:
>> -rw-r--r-- 1 tomcat7 tomcat7 4847 May  2 12:44 geowebcache.xml
>> drwxr-xr-x 2 tomcat7 tomcat7 4096 May  2 12:44 tmp
>> write permission seems to be available for the tomcat7 user.
>> Alessio
> Simone
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160503/7e3a9448/attachment-0001.html>
More information about the geonode-users mailing list
