[GeoNode-users] Uploading Arc ASCII grid
Simone Dalmasso simone.dalmasso at gmail.com
Tue May 3 09:58:04 PDT 2016
Hi. The command is $geonode updatelayers
Via manage.py is for custom installations and development.
Il martedì 3 maggio 2016, Arthur Abbott <aabbott at seafortheng.ca> ha scritto:
> Hi,
> I am attempting to upload an ASCII grid into geonode via geoserver.  I
> have successfully made the datastore and loaded the grid into geoserver.  I
> can preview the layer and query it.
> I understand that the next step is to run: *$ python manage.py
> updatelayers*.  Where is this script?  I did a search and found a copy at
> */usr/lib/python2.7/dist-packages/example_projects*.  It did not have the
> *updatelayers* as a subcommand.  Nor does it have the *importlayers* or
> *fixsitename* subcommands.  The version of the file is 1.6.11
> Am I missing a newer version of the script or is there another way of
> doing this?
> I installed via the quick install on ubuntu 14.04.
> Thanks in advance,
> Arthur
> Arthur Abbott
> GIS Technician
> Seaforth Geosurveys Inc.
> 300 Prince Albert Rd., Suite 200
> Dartmouth NS Canada B2Y 4J2
> P: (902) 468-3579 ext. 232
> F: (902) 468.6865
> www.seaforthgeosurveys.com
> Notice this communication, including any attachments, is confidential and
> is intended only for the person or persons to whom it is addressed.  If you
> have received this e-mail in error, any use, copying or distribution is
> strictly unauthorizes and you should delete it and any attachments.  Please
> also notify the sender by e-mail or telephone at 902-468-3579.  Thank you.
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160503/7e723185/attachment.html>
More information about the geonode-users mailing list
