[GeoNode-users] Styles not stylin'
Cliff Patterson cliffpatterson at gmail.com
Tue May 3 13:43:06 PDT 2016
Thanks for this suggestion, and you are definitely on the right track. I
reinstalled on a fresh Ubuntu install and everything now works flawlessly.
I have determined that since I had changed the default PG password and
modified the access permissions, it caused a few errors on the Postgres log
once GeoNode was installed -- namely the inability to access the GeoNode
DB.
Advice: do not install postgres prior to GeoNode. Install Geonode and let
the installer set up the DB.
So far this strategy is working and I am able to modify styles in GeoNode.
I have not, however, tested layers that reside in a PostGIS store. That's
my next test.
Thanks,
Cliff
On Tue, May 3, 2016 at 4:07 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Hi
> I am not familiar with the installation from package in Ubuntu but one
> of the possible things that could take to the behavior you are
> describing it is if you changed the default password for the geoserver
> administrative user. Styles are changed from GeoNode using that user
> and calling the GeoServer REST API.
> In such a case you need to change it accordingly in this location (or
> even better with a local settings file):
> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L505
> hope it helps
> p
> On Tue, Apr 26, 2016 at 9:59 AM, Cliff Patterson
> <cliffpatterson at gmail.com> wrote:
> > Greetings Geonode Users!
> > I'm new to Geonode, but familiar with Geoserver and PostGIS. I installed
> > Geonode from the ppa this week, and I am having a number of problems
> getting
> > a few critical components working. I am running Geonode on Ubuntu Server
> > 14.04.4 LTS.
> > I'll start this post with what I consider the top priority in my world at
> > the moment -- styling layers.
> > Basically, if I set a layer style in Geoserver, it appears in Geonode's
> > GeoExplorer with that style when I run "geonode updatelayers", but I am
> > unable to change the style from within GeoNode. If I make any edits in
> the
> > map view, those changes are not made either to the mapped layer and they
> are
> > not saved to geoserver. Basically, I have to completely remove a layer
> from
> > Geoserver and re-add it if I want to make any changes to a layer's style.
> > That doesn't seem right.
> > Next, if I change the style in Geoserver, that style is not changed in
> > GeoNode. No updates are made to the GeoNode layers (except in the
> thumbnail
> > for some reason). The layer will always display in its original style on
> a
> > map. It is almost as though there is a cache somewhere that needs to be
> > cleared (I cleared GWC, but that did nothing). I updated layers with
> > "geonode updatelayers" and restarted Apache. No change.
> > Note that I'm having these problems with both shapefile and PG/PostGIS
> > layers.
> > Can anyone point me in the right direction to get styles working with
> > GeoNode?
> > Big thanks!
> > Cliff
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
Clifford B. Patterson
PhD Candidate
School of Surveying
University of Otago
Email: cliffpatterson at gmail.com
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160503/5d7fdd59/attachment.html>
More information about the geonode-users mailing list
