[GeoNode-users] Change SITE_URL of GeoNode 2.4 installation
Marco Tosato marco.jem at gmail.com
Fri May 6 04:28:28 PDT 2016
Hi guys!
In my scenario the way to go was manual update of the base_link and
base_resourcebase tables since the new URL has both a new domain and a new
path for GeoNode.
Thank for your support :-)
2016-04-30 19:24 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi,
> have you used the command "$ sudo geonode-updateip yourdomain" ti change
> it? It should take care of everything for you, if is not doing that then we
> might have a bug :)
> Ciao
> 2016-04-30 18:55 GMT+02:00 Israel López <asralf at gmail.com>:
>> Yes, in fact, maybe you cannot see  thumbs and download the resources
>> too, in the case of the legend, you should modify the global setting in
>> geoserver, and for the database I'm not sure if there is a tool but I've
>> modified by hand the tables resourcebase and links.
>> The experts could give you more info.
>> Hello everyone :-) I'm having a issue with GeoNode, tried to google
>> around for a solition but not able to find one.
>> Basically I need to change the SITE_URL of my installation (GeoNode2.4),
>> the problem is that after changing his setting the legend of the layers
>> disappers, the legend image still points to the old URL despite having
>> restarted apache and tomcat and having cleared the geoserver cache.
>> Have you got any suggestion to fix the proble? Maybe GeoNode stores the
>> links or the address of the server somewhere in the DB?
>> Thanks in advance
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160506/89c6efc9/attachment.html>
More information about the geonode-users mailing list
